TIEN Flex
bjones
TIEN Flex
Postby bjones » Thu Jun 07, 2007 1:53 pm
Has any one used read about compared the tien flex (not the ss) if so what are your thoughts
Thanks
BJ
Playing with BOOST will smoke your tyres!!!
NO LONGER MINE sob sob
Babalouie
godfather of saké
Postby Babalouie » Thu Jun 07, 2007 2:55 pm
CT has Tein Flex...
Juffa
Postby Juffa » Thu Jun 07, 2007 3:22 pm
Over the course of the past 8.5 years I have owned three NA, with the following spring/shock combinations.
1. King/Koni
2. Mazdaspeed (Eibach)/Koni
3. Tein Flex (current)
I found the king/Koni combination to be very stiff and too much of a compromise for day to day driving. I did play around with the adjustment on the Konis but was never 100% satisfied.
The Mazdaspeed/koni combination while better that the king/koni setup, in that the ride was more compliant, was still a compromise.
Now that I have the Tein Flex installed (without the upper pillow mounts) I am very happy. I love being able to adjust the ride height without reducing the suspension travel and being able to make that ride height adjustment for all four corners in around 40 minutes. While I have not actually done it, I believe that the coilovers will allow for easy corner weight balancing.
My 2.2 cents worth
J
Kvision
Postby Kvision » Thu Jun 07, 2007 8:26 pm
CT
Postby CT » Thu Jun 07, 2007 10:40 pm
The Flex in old skool style twin tube will be more than suitable for a car the weight of an MX5. I've had them for 4 years now first the NA race car and now on the SE. In fact, when I first used them everyone else used konis, now, everyone uses Teins.......they have far superior low speed damping to any other shock I've used on an MX5 and the range of adjustability makes them a very, worthy investment. A shocks role is to control spring oscillations - not to limit roll - that's what sway bars are for. If you can afford to, the monotube has benefits but really, how many people could really tell the difference...... 8)
Casey
Postby Casey » Thu Jun 07, 2007 11:14 pm
CT wrote:A shocks role is to control spring oscillations
Which is why they are called dampers, not shocks, shock absorbers, shockies etc. The springs are really the shock absorbers.
Sorry - one of my pet hates. Back to normal programming 8) :mrgreen:
White SP Image
CT
Postby CT » Fri Jun 08, 2007 1:55 pm
Casey wrote:
CT wrote:A DAMPERS role is to control spring oscillations
Happy :mrgreen:
Babalouie
godfather of saké
Postby Babalouie » Fri Jun 08, 2007 2:27 pm
I thought damper was a kind of bread.
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Fri Jun 08, 2007 4:05 pm
I have just fitted a set of the Mono Flex(really nice bit of gear) on the race car,havn't dríven on them yet but am doing oran park next weekend so will have some feedback then.
All this talk about damper has made me hungry...time for a snack...
Juffa
Postby Juffa » Fri Jun 08, 2007 4:29 pm
Well done Casy...this is the first time in ages that you have brought this to our attention.......was wondering how long before you cracked. :D
rjastra2
Postby rjastra2 » Fri Jun 08, 2007 4:49 pm
anti-sway (remember the anti! ) bars are nothing by springs themselves 8)
Firmer dampers do give the \"impression\" that they reduce roll. I assume it's just because they seem to control the rate at which the car actually rolls.
Casey
Postby Casey » Fri Jun 08, 2007 7:06 pm
:mrgreen: :mrgreen:
White SP Image
bjones
Postby bjones » Sat Jun 09, 2007 1:07 am
Thanks Guys budget just had a grenade put under it.. Off to mania
BJ
slammer
Postby slammer » Thu Jun 14, 2007 2:48 am
Lou
What's your call on the Mono?
Worth it?
Not that I can afford it right now :D
http://members.optusnet.com.au/~slammer NA6A 16.1 1/4 , 1:13.57@Wakefield
Postby Okibi » Thu Jun 14, 2007 2:07 pm
I love my flex :mrgreen:
I was one of the lucky people that Tyrone bought sets for whilst in Japan.
