Wheel alignment
Blue94t
Wheel alignment
Postby Blue94t » Thu Jun 07, 2007 12:03 pm
Hey guys,
Had a wheel alignment done on my car last night by Craig at Trackside tyres in Bayswater, Victoria. The existing alignment was way out and it has transformed the car.
All this is in preparation for competing in the 07/08 Vic MX5 club championship.
The service out there was excellent and Craig is very helpful with advice on tyre choices and car setup. He was even happy to start the alignment at 5pm after I finished work and we rolled it off the hoist about 6:30pm.
I highly recomend Trackside for any tyre/alignment requirements for your MX5.
http://www.tracksidetyres.com.au/
Jake
btw, I am in no way affiliated/sponsored by Trackside, just wanted to share my good experience with a workshop. If this is innappropriate I am happy to remove the post.
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Thu Jun 07, 2007 1:51 pm
No need to remove the post I'd think - why should you even have to??
Isn't half the reason we have the forum to share good and bad experiences of service providers etc, as a publci service to our fellow forum dwellers??????? :D
Col
Vehicle: 10AE
Postby Col » Thu Jun 07, 2007 2:32 pm
Good news Jake. I should have mine checked/adjusted too. I've put it off for 2 main reasons: 1) The car seems to handle how it should.
2) I'm very careful who I trust to work on my car.
I haven't played about with different alignment settings like others have and I'm starting to feel that although I'm basically satisfied with the cars handling, that maybe it could be further improved with a good alignment.
I think I should just do it.
Thanks,
Col
Happy 10AE man [#5128]
Garry
Postby Garry » Thu Jun 07, 2007 3:12 pm
Anywhere from around $60 to $120. Depending where you take it.
Col,
Definitely recommend getting a GOOD alignment. It can transform your car, the same way as a bad alignment can really stuff it up. Take it to someone that knows what they are doing, preferable with a bit of MX5 experience. Generally try to avoid your Bob Janes etc.
RDM
Postby RDM » Thu Jun 07, 2007 7:30 pm
[quote="Garry"]Anywhere from around $60 to $120. Depending where you take it.
Col,
Definitely recommend getting a GOOD alignment. It can transform your car, the same way as a bad alignment can really stuff it up. Take it to someone that knows what they are doing, preferable with a bit of MX5 experience. Generally try to avoid your Bob Janes etc.[/quote]
So does anyone recommend the service at AMR in Petersham? I had my first alignment done by them to stock specs about a year ago now... didn't seem too bad afterwards but it did take a while for them to do it.
Was also now considering getting a racier spec alignment done before the next EC Mania trackday so if no one has any other suggestions on local alignment places, I might just go back to AMR seeing as it's still under warranty with them... will go for -2.1 front -2.2 rear camber, zero toe and max castor... that about right for R888 in 205/40R17?:?:
RDM
Fatty
Postby Fatty » Thu Jun 07, 2007 8:58 pm
just to confirm what garry said about avoiding yr loca bob jane etc...
when i got my new tyres / wheels fitted at the local bob jane they did an alignment for me. nowhere near as good as it used to be, when it was set up by someone familiar with mx-5's ( previously it was done via mx5 factory in ringwood, felt much better)
so yeah i will get it re-done again soon. the bob jane guys just set it up for minimal tyre wear as far as i can tell. performance / handlng is not a priority.
Garry
Postby Garry » Fri Jun 08, 2007 9:30 am
RDM,
AMR!!! *shudder*, *runs away screaming*
For the last few years I've been taking my car to Spinning Wheel. Stu has a fairly large MX5 customer base now so he's done a few MX5's before. Tell him what you think is wrong with the way your car steers and he will work his magic and fix it up for you. The good thing about them is that if you're not happy with the way Stu has set up your car you can take it back within a few days and he'll have another play with it. They charge $88 for a 4 wheel alignment.
Blue94t
Postby Blue94t » Fri Jun 08, 2007 10:03 am
khchu,
It cost me $80.
Col,
I too am very fussy who I will let work on my car. Craig does a great job and was happy to let me watch as he did the work.
Jake
green_comet
Car Detailing Guru
Postby green_comet » Fri Jun 08, 2007 10:07 am
Sounds great Jake,
Ill take mine down to him when i get the new wheels on in the next couple weeks.. What were your final settings, if you dont mind me asking??
Col
Vehicle: 10AE
Postby Col » Fri Jun 08, 2007 11:30 am
I'll be seeing Craig at Trackside soon. Thanks Jake.
Boags
Postby Boags » Fri Jun 08, 2007 7:52 pm
drifter wrote:I mean, would the old tyres offset the benefits of a good alignments?
No. Why have crap tyres and a crap allignment? :D
muzza2
Postby muzza2 » Wed Jun 13, 2007 7:20 am
im getting mine done at action tyres (tyre tech - stafford) at 8am today...
wish me luck! :D
$55 for all 4 paws...
fulcrum were booked out and my schedule didnt meet for like 2 months!
RDM
Postby RDM » Tue Jul 10, 2007 1:40 pm
[quote="Garry"]
quote]
Hehe... I'm beginning to see the error of my ways... :oops:
The only reason I use them is that the car is still under factory warranty and has an extended dealer warranty with them so long as it's serviced there. Though with each visit, I keep telling myself it'll be the last time cos I've had quite a few dramas with them (lots of stories that I'll keep off forum).
In any case, I've just got the car back after an oil/filter change and a wheel alignment. The wheel alignment machine printer has apparently broken so they couldn't give me a printout of the measurements pre/post alignment. But they did type it up in the service report
Front Camber: L 1.11 R1.12 (max possible from OEM suspension)
Front Castor: L 5.32 R 5.23 (max possible from OEM suspension)
Front Toe: L 1.9mm R 1.9mm (don't know if that's out or in but I did ask for toe-out)
Rear Camber: L 1.40 R 1.41 (max possible from OEM suspension)
Rear Toe: L 1.8mm R 1.9mm (again don't know if that's in or out but I asked for toe-in)
After the drive in to work this morning, I noticed the steering feel was 'muted' (heavier, less feedback and less twitchy than I was used to from the OEM spec). I pushed quite hard in a few of my favourite turns and noticed the rear end was much easier to catch once a slide was provoked, but I can't say I like the front... it just feels very 'slow' (maybe it's my degrading reflexes :shock: )
I'll take the car to Spinning Wheel to get another alignment done after tomorrow's Mania Track Day... will be interesting to see how it behaves with the 205/40R17 R888s... been waiting to use them in anger for quite a few months now! :D
RDM
Charlie Brown
Postby Charlie Brown » Tue Jul 10, 2007 2:10 pm
What model MX5 do you have RDM?
If it's an NC then you are nowhere near the maximum negative camber.
If it's an NB then you should still be able to get more than they said, especially if the castor is backed off a little.
Next, if you have a dead feel in the front there is no way that it is set ‘toe out’. With that much ‘toe out’ you would be diving all over the road.
As for the 888s you need over 2 degrees negative. You will find that the insides won't be getting any wear at all.
The camber set up they have given you is really just a slightly aggressive road set up.
RDM
Postby RDM » Tue Jul 10, 2007 4:59 pm
[quote="Charlie Brown"]What model MX5 do you have RDM?
The camber set up they have given you is really just a slightly aggressive road set up.[/quote]
NB SE. They said that that was the maximum the stock stuff would allow and didn't want to try for any more. I didn't think I'd get -2degrees with the standard suspension so -1.4 seems ok. Disappointed with the front setting though...
As for the R888 at these settings, my guess is I'll start with cold pressure of 34psi and work towards getting 38-40psi hot to try keep the outer edge from wearing out prematurely.
Still, I can't really complain about the OEM alignment settings either. I've had 2x 30k wear out of Conti SC2s and it was even across the entire width of the tyre for all 4 tyres (I rotate them religiously at 5k intervals)... I know I definitely won't get that on the current settings (and given I can't slip tyres from inside to outside, the insides will always wear out first.
I guess I could drive quicker than I currently drive to use the outside edge more!!! :mrgreen:
Users browsing this forum: Google [Bot] and 8 guests
