Adjusting nozzle from GB
EGG80X
Postby EGG80X » Wed Jun 06, 2007 4:10 pm
anyone know how to adjust these noozles?
Mine spray over shoots the windscreen lol....
I know with the old one you can adjust the aim of the spray with a pin or toothpick but dont know bout these ones
Garry
Postby Garry » Wed Jun 06, 2007 4:21 pm
Are you sure they are clipped into the bonnet properly? Mine seem to be aimed OK though I read on the miatanet thread that the NA ones shoot up a little to high.
Boags
Postby Boags » Wed Jun 06, 2007 4:23 pm
Yeah, Sabretooth's left nozzle was spraying over the roof to start with, turned out it wasn't clipped in the whole way.
They do spray quite high on the wndscreen though...
Boags
EGG80X
Postby EGG80X » Wed Jun 06, 2007 4:26 pm
cheers guys
*grabs the hammer, runs out screaming towards the front of the mx.....
StanTheMan
Postby StanTheMan » Wed Jun 06, 2007 4:33 pm
:shock: :shock: :shock: OMFG eggy....
EGG80X
Postby EGG80X » Wed Jun 06, 2007 4:48 pm
StanTheMan wrote::shock: :shock: :shock: OMFG eggy....
its a stressfull day... need to vent out lol
Boags
Postby Boags » Wed Jun 06, 2007 7:38 pm
:lol:
You guys crack me up.
Ajay
Postby Ajay » Wed Jun 06, 2007 10:50 pm
arent these designed to clean the window of the car behind you?.. :lol:
i fiddled with mine a bit and got them down a bit lower.. still get wet when the tops down :evil:
Babalouie
godfather of saké
Postby Babalouie » Thu Jun 07, 2007 12:03 am
mx5_boy wrote:arent these designed to clean the window of the car behind you?.. :lol:
Aren't they off a USDM Tribute or something? That's got a much taller screen than a '5 :D
Fuzzlet
Postby Fuzzlet » Thu Jun 07, 2007 2:17 am
When I fit mine I'm gonna look at using a thin piece of rubber as a spacer at the front of them, to try to angle them down a little
bigdog
King of the kennel
Postby bigdog » Thu Jun 07, 2007 10:53 am
Mine are perfect when driving, but too high when stationary. Not a problem as I only use them when driving.... :D If you change the thick ness of the spacer they will either rattle around (too thin) or not fit at all (too thick). They're made to fit the panel thickness snuggly, so if you wanted to change the fit you would need to do some plastic trimming and fiddling - would be easy to stuff it up.
Fuzzlet
Postby Fuzzlet » Thu Jun 07, 2007 1:07 pm
In that case....bugga lol
Babalouie
godfather of saké
Postby Babalouie » Thu Jun 07, 2007 2:55 pm
Yes but instead of reefing back on the wiper wand for a 10 second water blast, can't you just goose it to half-throttle to just get the squirt to the halfway point on the screen?
Have you guys all forgotten about throttle control? :)
Benny
Postby Benny » Thu Jun 07, 2007 3:45 pm
Babalouie wrote:Yes but instead of reefing back on the wiper wand for a 10 second water blast, can't you just goose it to half-throttle to just get the squirt to the halfway point on the screen?
Exactly!
I usually give it a few quick pulls of the lever to get it spraying all over the wondscreen and hardly get a drop inside the car if I'm moving or stationary.
A few short sprays work better than one big, long spray.
It uses a lot less water too.
Ajay
Postby Ajay » Thu Jun 07, 2007 3:46 pm
hahaha benny i do the same thing :lol: ahhh great minds
Users browsing this forum: No registered users and 161 guests
