Hi all
Just seeing if anyone's try Konis with Pedders springs?...how much should you expect to pay for this setup used?
From what I've heard, Pedders are low but soft?...possibly Monroe rebadged?
Minh
Konis on Pedders springs?
- Mr Starlet
- zoomzoom
- Vehicle: NA6 - Turbo
- Mr Starlet
- zoomzoom
- Mr Starlet
Sav wrote:I have pedders with koni's and they are fine.
On the track my car is very similar to other people with different set ups.
Pedders is a good aussie company, I reckon.
Kings are also aussie, at the gold coast the last I heard. From looking at the two (right here in front of me) I dare say that they are the same apart from the colour. Even the spring rate feels the same, I wouldn't think pedders would make their own...most likely outsourced elsewhere, could even be the same plant the Kings are coming from.
Hey Tim, when you had Pedders on your rear, what was the rest of your setup?
- MxJadeMonkey
From my last job working only with suspension i might be able to clear a few things up!!
Monroe is sh*t no matter what product it is, anything monroe (burn it)
King springs have a lifetime warranty against a free height sagging of 10mm or more. (kings are fantastic springs and are aussie made in QLD) kings are made as a hot wound process not cold wound so less stress fractures, hence no sagging
Pedders do make their own springs (from memory) and are known too sag more than a king spring
Koni is also a fantastic way to go in terms of shocks (they also do coilover kits for the na/nb model's !!!! little known fact) oh and just springs too
As for spring rates???? most after market springs are about 30% firmer than a factory spring. (kings usually being firm but not too hard)
Hope that clears up some things for u!! ( not that i was asked or anything anyways!!!!!! haha haha
In case your wondering i run a KYB/KINGS combo with every bush in super pro poly (offset) about to be added along with signiture adj front and rear bars, with TEIN strut brace front.
1991 NA6 Velocity Blue (Ford Colour)
- Bevan
- zoomzoom
They were on my car when i got it, just with std shocks. They were a linear rate and had heaps of coils compared to my king which are progressive and far fewer coils, making the kings much firmer and the red ones way too soft. By the time I took them out my exhaust was absolutely stuffed.
Tim
PS: I sold many many monroe shocks and in my experience they are a very good shock, many of them are also made in Aus.
Tim
- MxJadeMonkey
Users browsing this forum: No registered users and 159 guests
