Boost controller suggestions
sabretooth
Postby sabretooth » Fri May 25, 2007 3:35 pm
Does anyone have any suggestions for some nice solid boost control? I just want to run 13psi. I won't be adjusting it myself, but I want it to be reliable.
I've seen the Jaycar ones - they look ilike a good solution, but one of the guys @ Mercury Motorsport reckons they're inconsistent. Any other experiences?
PT
Postby PT » Fri May 25, 2007 4:14 pm
He'll say they are inconsistent because he does not sell them.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Marador
Postby Marador » Fri May 25, 2007 4:37 pm
I ran a bottom of the range turbo smart boost controller on my S15 for about 12 months. I found it worked fine and the boost was pretty consistant. I think that set me back a whole 100$
Im looking into a more advanced option for the sp thou, because i want different levels of boost in 1st/2nd to 3rd/4th etc :P
Silver SP
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Fri May 25, 2007 5:05 pm
manual or electronic?
sabretooth
Postby sabretooth » Fri May 25, 2007 5:19 pm
PT wrote:He'll say they are inconsistent because he does not sell them.
Funny you say that, he then recommended a Turbosmart he sells.
Either manual or electronic will do fine.
Boags
Postby Boags » Fri May 25, 2007 6:43 pm
I made my own from parts at my mates workshop = $0
I get 9 PSI rock solid, no creep, no overboost and no spike. If I want more I just turn the knob clockwise. 8)
If you don't have a mate with a workshop, UA bought the exact same thing on eBay for just next to $0... They aren't very expensive cause they are dead simple and they make sense because they are mechanical.
I believe UA loves his too! :D
Boags
sabretooth
Postby sabretooth » Fri May 25, 2007 8:19 pm
Is it a ball, or needle? From what I've read, the ball ones are effective but they drop off. I've seen the AutoSpeed one and it looks interesting, but I didn't like the way the boost dropped off in their graph. Gah, I dunno!
Sean
Postby Sean » Fri May 25, 2007 9:07 pm
sabretooth wrote:Is it a ball, or needle? From what I've read, the ball ones are effective but they drop off. I've seen the AutoSpeed one and it looks interesting, but I didn't like the way the boost dropped off in their graph. Gah, I dunno!
AT low boost hey wont drop off that much, I've set up an MX5 with one of the $20 ebay ones and it held rock solid 12 - 14 and 16 psi.
The only bit I didn't like was setting it up, gee it was hard to adjust, it seemed 12-14psi was bugger all adjustment/screwing, then 14 - 16 was a lot bigger change required....
Just be sure to only adjust a bit at a time to prevent overboost to HUGE numbers...
For $20 I can't fault them, at least as good as the $90 GFBs etc.
Uncle Arthur
Postby Uncle Arthur » Sat May 26, 2007 4:23 pm
Boags
I do - it is excellent - look on autospeed for the $30 boost controller
The Pupat
Postby The Pupat » Wed Jun 13, 2007 3:28 pm
SMC part number ARP3000 - Direct Operated Precision Regulator Modular Style or festo equivalent. A mate of mine used the festo equivalent on an SR20 with a GT3040 and it worked prefectly with a 40odd mm external gate. He tested it from gate pressure (of 7psi upto 18odd psi without a drama). They are rate from .005 to .3MPa (.8psi to 40-odd psi) with a setting sensitivity of .001MPa and a repeatability of .003MPa (.45psi). My mate swore by it. Otherwise another mate swears by the blitz stuff for boost controllers (can't remember the exact model) holds flat as and really helps pick up response as it's coming on.
'92, Red, Hardtop, Noisy CAI, Even more Noisy Exhaust, AVO Shocks with TJR Springs (Not so Fuli drifto speco).
Garry
Postby Garry » Wed Jun 13, 2007 4:20 pm
I have a Blitz EBC and running under 10PSI it seems to work fine. Looking at the readout on the screen the boost is very consistent. It feels like there is more boost at lower revs and the transition onto boost is much smoother than it was using just the wastegate as the controller.
I tried the $40 manual controller that the Skyline guys/Autospeed raved about and found the boost to be inconsistant and came on with a big rush. Setting it up was a pain too. The thread pitch on the adjuster is way to coarse.
Grumpy
Postby Grumpy » Wed Jun 13, 2007 7:43 pm
My MX6 has and electric Mazspeed unit which works fine. Normal boost is 7lb and 14 with it turned on. It is adjustable with a screwdriver to get it right. Was running 18lb for a while but thought it was a bit high, besides, the front tyres were starting to suffer.
Sadly MX5 less for a while.
Rebuilding an 89 Honda CRX
