NA front swaybar help
just got the front swaybar off Rob E last night, installed it today but noticed that the left side of the swaybar rests on the upper arm.
driver side is fine with a 2 - 3 mm gap.
i used the bushes it came with, the OEM mounts and OEM links
when mounting the swaybar i wasnt able to adjust any movement of the ends and thought that after i let it down it might magically move in place.. but i was wrong
took it for a drive and it makes a clunking noise with every bump i go over
i think its a whiteline sway bar, does it matter which end goes where, i didnt actually check it for any left / right markings
any help appreciated
heres some pics
passenger side hitting upper arm
top view of passenger side hitting upper arm
driver side frontal
sort of top driver side
driver end links
passenger end links
heres some pics
driver side frontal
driver end links
passenger end links
- Garry
- Garry
My workshop manual doesn't mention a left or right side. It might be an idea to take it off and compare it to the original bar to make sure it is the same shape and you dont have an NB bar, which will also fit with a few mods apparently.
- Astroboysoup
i got the whiteline non adjustable front sway and its nothing like that it was a perfect fit
AustCars.net - It's like Facebook but for cars!
no its not an import
i thought the amount of surface rust for a car this old would be ok...
seems as though everyone who's fitted a 22mm bar has had no problems on an NA... i must be special
hopefully whiteline would be able to compare their bars with mine, or recommend on an endlink setup as the endlinks i got move the bar back and i cant screw in the mount
- bigdog
- King of the kennel
- Matty
lam.666 wrote:hmm ... doesnt look bent to me...
does it look like its bent to anyone else?
This very bar came off Mattys NA6 with no fitting probs.
Its either a bent control arm or the bar is bent - and the bar aint bent. I'd reckon the previous owner has put that car into the gutter or a traffic island.
Users browsing this forum: No registered users and 224 guests
