What you got, where you got them and how much.
kula
Postby kula » Mon Mar 19, 2007 11:08 am
Type:Kuhmo Ecsta SPT
Price: $90 per tyre
Dry Grip: Very Good
Wet Grip: Good.
Tyre Life: Expected to be good, >20k.
Road Noise: Low-mid, dont really care.
marcusus
Postby marcusus » Sat May 12, 2007 11:59 pm
Thread revival!! (I'm hunting for info, and have found a vast treasure trove of randomly useful threads)
Price: $100 / corner
Dry Grip: 4/5
Wet Grip: 3.5/5 because I haven't pushed them hard enough in the wet to see if it'll make the grade of 4.
Tyre Life: Would not have a clue.
Road Noise: Stereo's up too loud to hear any road noise :P
Kula: where'd you get yours for $90 a corner?
Andy Wana
Postby Andy Wana » Sun May 13, 2007 12:24 am
Type - Michelin Pilot Preceda 2 (PP2)
Size - 195/50/15
Price - $150/tyre
Place - Bob Jane Brookvale (look for David or Grant)
Dry grip - Two thumbs up (very grippy)
Wet grip - Two thumbs up
Tyre life - Not sure - only done 500km.
Road noise - Very low
I ♥ asymmetry
Postby manga_blue » Sun May 13, 2007 1:05 am
These were on the other car, just posting this here in case anyone would consider them.
Type: Michelin Energy
Price: on the car new
Dry Grip: None (also Turn-in: None)
Wet Grip: Even less
Tyre Life: Infinite. No one could spossibly suffer these tyres long enough to wear them out.
Road Noise: Not sure, you don't notice it because the harsh ride is hurting you so much already.
Special mention for puncture resistance: nil
Grip and ride would be better if you took the tyres off and just ran on the rims. Ditched them after 20% worn because of repeated punctures. Partner has been saying thank you for buying me new tyres every day since.
Postby manga_blue » Sun May 13, 2007 1:20 am
These replaced C-Drives on 14\" rims
Type: Goodyear Eagle F1 (GS-D2)
Price: ebay, came free with the wheels
Dry Grip: Similar to C-Drives, but noticeably quicker turn-in
Wet Grip: Never rains here
Tyre Life: Dunno.
Road Noise: Tread block noise and some comes through as vibration into the car (SuperPro poly bushes).
Took over 1,000km to scrub them in. Diabolical initially. They're generally stiffer and harsher than the C-Drives but they're also much more responsive. Tend to let go front or back without much warning but other forums suggest higher pressures cure this.
zoomzoom
Vehicle: NA6 - Turbo
Postby zoomzoom » Sun May 13, 2007 3:03 am
These replaced the Bridgestone Potenza G3
Type - Toyo Proxes T1R
Size - 205/50/15
Price - $169ea
Dry grip - Grips well, a little better then the bridgies, but very squirmy, much softer side walls
Wet grip - they do!!!
Tyre life - about that
Road noise - low, except for cornering, side blocks are fairly noisy
hillsend
Postby hillsend » Sun May 13, 2007 4:55 pm
Replaced Dunlop Lemans LM 702 with
Size - 205/45/16
Price - $185ea Tyrepower Miami
Dry grip - Good, my sidewalls don't seam too soft compared to Lemans.
Wet grip - Good
Tyre life - ?
Road noise - low
I am running 30psi havn't tryed much else, tyrepower had 45psi in them
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Mon May 14, 2007 6:17 pm
Just what we use...
Type -Dunlop SP Sport Slick
Size -220/550/15
Price -$350 ea.
Dry Grip -WOW!!!
Wet Grip -Are you crazy?
Tyre life -About 300km if you are lucky...
Road noise -Can't hear much through the helmet.
JBT
Postby JBT » Mon May 14, 2007 7:23 pm
Size - 205/45/17
Price - $10,000 each - free NC thrown in :mrgreen:
Dry grip - Fantastic
Wet grip - Fantastic
Tyre Life - NFI - ask me again in a couple of years.
Road noise - Stuff all
bigdog
King of the kennel
Postby bigdog » Fri May 18, 2007 12:47 am
New set of T1Rs fitted today.
Last set gave me 35000km of often 'spirited driving' :D
205/45x16 replacing 215/40x16 (not available and much more exe).
$160ea at Blairs Narellan.
I have no issues with alleged side wall squirm - handles brilliantly wet and dry.
Beware though, I had several quotes of $220 and $240 for the same tyres elsewhere. It pays to ring around!
:lol:
Slugoid
Postby Slugoid » Fri May 18, 2007 3:41 am
Type - Yokohama Advan A048 (medium compound)
Size - 195/50/15
Price - $750 all 4 (80-90% tread)
Dry grip - Bloody excellent! Well compared to street tyres :lol:
Wet grip - Don't want to know :P
Tyre life - If it can last 2-3 more track days I'm happy :)
Road noise - Very noisy, but don't care. Only have to endure them to and from track.
irwin83r
Postby irwin83r » Fri May 18, 2007 6:16 pm
bridgy gt3s
price: cant remember for the life of me
dry grip: great
wet grip: very good
tyre life: pretty good around 15k.. some track work.
the only thing lacking was turn in.. but that was more due to silly tyre size. but god it looks sweet 8)
Kumho V70A
price: special @ mania 40bucks each :wink: 30%-40% tread but quoted 260 a corner else wear new
dry grip: first semi slik so a bias freakin sweet.
wet grip: had a low amount of tread by the time i ran them in wet so not alot.
tyre life: again cant comment as half dead by the time i got them but hear good things.
V70As i hear alot of people love for the fast warm up and next to no effect from heat cycles but arent up to D01 speed on track- im yet to confirm this myself but can see these tyres been ok for the supersprinter or weekender that dose a bit of track as the road wont screw em too fast and are liveable on the road.
p.s best thread ever
Boags
Postby Boags » Sat May 19, 2007 9:45 am
irwin83r wrote:p.s best thread ever
Thanks. 8) :mrgreen:
Mr Starlet
Postby Mr Starlet » Wed Jun 06, 2007 11:45 am
Type - Toyo T1R
Size - 215/40/16
Price - $176/tyre (balanced & fitted)
Dry grip - They're great but hard to compare 'cause my last set was 195s that are dried to the bones
Wet grip - Same, quite good, no aquaplaning as far as I can tell, I would think that having wider base and lesser effective contact area they would be slippery but non of that so far.
Tyre life - ~10000km, everyday & spirited & track driving...not even half way yet.
Road noise - can't tell but who cares anyway
I'd buy again but even wider at the rear to accomodate the 8\" wide rim.
CoffeeBoss
suntory
Postby CoffeeBoss » Mon Jul 02, 2007 7:18 pm
Size - 215/45/17
Price - $305/tyre (12months ago - balanced, fitted, filled with N2)
Dry grip - Excellent, don't squeal until right on the limit. Nice stiff sidewall
Wet grip - Not superior to, say, Eagle F1 but still nice, progressive on the limit.
Tyre life - ~40000km, everyday & spirited driving (1370kg car too!)
Road noise - probably average compared to what i used in the past - Dunlops, Eagles, Rainsports.
Just purchased on the weekend:
Type - Michelin Pilot Primacy
Size - 225/45/17
Price - $315/tyre (balanced, fitted, filled with N2)
Dry grip - Excellent, don't squeal until right on the limit. Sidewall not as stiff, altogether not as responsive on turn in. A trade off for dramatically improved ride quality, and much less bump steer (a product of my tight coilovers/stiff 12kg/10kg spring rate)
Wet grip - So far i would say much superior to Preceda's.
Tyre life - ?
Road noise - noticeable lower than the Preceda's.
A part of me wonders how i would have found the PP2's.... but since i have discovered Wakefield, different wheels and tires will be sought for 'that' kind of driving.
Anyone else quoted on Primacy's? Curious to know if i was dealt a good deal or not.
Matt
