WAKEFIELD PARK - Monday 7th May
ampz
Vehicle: NA6 - Turbo
Postby ampz » Tue May 08, 2007 9:33 am
Wow!
It is the best way i can describe yesterday.
First of all let me thank the organisers and all the behind the scenes people that make days like this happen!
My start to the day was less than glorious spinning twice during the instruction laps :oops: and turning a very dissappointing 1.37 in my first solo run...
But I did manage a PB by the end of the day at 1.23.69 :shock: 8)
I couldn't get to sleep last night as i was still too excited.
Thanks again!
Nuno
Huh?
brenno
Postby brenno » Tue May 08, 2007 10:11 am
I had a great time yesterday!
I picked up my NA8 (stock, except for Konis and a strut brace) a few weekends ago, slapped on some old and worn Toyo R881's I had, and managed a 1:16.4 PB.
Gotta be happy with that!
A big thanks to those that helped put the day together yesterday.
White NA8
Fuzzlet
Postby Fuzzlet » Tue May 08, 2007 6:14 pm
Yes, was a great day, except at one point drifting the 2 corners at the top of the hill...without trying haha.......that and me spinning on turn 1 :oops:
irwin83r
Postby irwin83r » Wed May 09, 2007 9:27 pm
holy cow CB! you almost cracked the class record by rod! a 1.6 sec difference in times really says alot about your old tyres :? but your certainly looking to be the one to catch now :twisted:
Matt..... we are so screwed... 1.13s! what the hell we going to do to catch up now :shock: :P
hope the extinguisher fits well.. should of stuck it in on monday and seen if it made and noises :P should be fine though 8)
so were dan and dav drivin on monday or just dav? that car is really really quick and nicely setup... but credit where credit is due, those two fellas are great drivers. i notice they finally gave in and put the black rims on :P looks hot as especially with those tyres 8) think i heard someone say the mania car has pulled a 1.03.XX before? this true?? thats even more crazy
Craig
Postby Craig » Wed May 09, 2007 9:31 pm
Charlie Brown wrote:I turned up the wick on the NC to put six or seven laps in the 1:13 bracket with a PB of 1:13.46 and take out a Class 5 win. 8) Was also the quickest naturally aspirated MX5 on the day :D
A 1.13.46 on street rubber...phuck a duck! :shock: :!: 8)
Bevan
Postby Bevan » Wed May 09, 2007 11:26 pm
Were they street tyres or DOT approved shagged semi's? They look pretty chunky and tuff. 8) What sort of tyres CB? I might keep my eye open for a used set if they are a softer tyre. :)
Charlie Brown
Postby Charlie Brown » Thu May 10, 2007 10:28 am
Craig wrote:A 1.13.46 on street rubber...phuck a duck!
Not street tyres but well used and abused DOT semi's, as I said in an earlier post.
Bevan wrote:Were they street tyres or DOT approved shagged semi's? They look pretty chunky and tuff. 8) What sort of tyres CB? I might keep my eye open for a used set if they are a softer tyre. :)
Kumho V700 up front (from the Lotus Series a year ago) and Dunlop D01Js (from the Commodore Cup) on the rear.
Next time out I hope to have shagged D01s all round as the Kumho’s were at the maximum limit for the rim size.
I’m wrapped with the time considering that there’s only 91kW ATW and If I get the tyre pressures right maybe there’s a chance to improve on that time. I can only hope.
Just goes to show you Mazda designed a great car for the average 'Joe Blow' to have some fun in.
Casey
Postby Casey » Fri May 11, 2007 7:16 pm
Were you using 16" rims?
Charlie Brown wrote:Just goes to show you Mazda designed a great car for the average 'Joe Blow' to have some fun in.
Very impressive times - clearly you're not an average Joe Blow 8)
White SP Image
Charlie Brown
Postby Charlie Brown » Sun May 13, 2007 9:48 pm
Casey wrote:Were you using 16" rims?
Hi Casey,
Yep, 16" rims of a mid 90's RX-7 (Series 5/6?). With the 50 series tyres the diametre worked out the same as the standard 17" with a 45 series tyre.
Offset was only 3mm different from the standard 55mm offset.
Casey
Postby Casey » Mon May 14, 2007 12:07 am
Hi Casey,
Series 6 - very light for their size.
I've got the V700 as my road tyres and am very happy with them - they don't seem affected by heat cycles like some other DOT tyres, so they should be okay when I finally am able to get to the track again 8)
White SP Image
Bevan
Postby Bevan » Thu May 17, 2007 4:21 pm
Hi Casey,
I wouldn't exactly call them "shagged" and ready for the tip for a semi slick. :?
Li7hium
Postby Li7hium » Thu May 17, 2007 4:29 pm
Evidently CB has far too much moolah if he thinks those tyres need to be thrown on the scrap heap. You should have seen my \"more slick than semi-slick\" tyres that weekend.
Thankfully, I shall be rolling on new R888s at this weekends Supersprint.
Hey Bev, I think I have bested your best time! :P
Matt
NA8
Wakefield 1:14:78 28-6-09! Oran Park GP 1:27:73 30-03-08 Oran Park South 54:50 14-10-2007 Eastern Creek 2:02:44 6-8-07
BRZ
Pheasant Wood 1:05.4940
Charlie Brown
Postby Charlie Brown » Thu May 17, 2007 8:20 pm
Li7hium wrote:Evidently CB has far too much moolah if he thinks those tyres need to be thrown on the scrap heap. You should have seen my "more slick than semi-slick" tyres that weekend.
Matt
Hey you should see the front ones :!:
Fronts cost me $40 the pair and the rears $50 the pair :D
Return to “MX5 Motor Sport”
Users browsing this forum: Bing [Bot] and 3 guests
