What is different about the NA8C BP-ZE and NB8A BP-ZE
Matty
Postby Matty » Mon May 14, 2007 8:11 pm
See solomiata.com - quite a few changes but the heads are interchangeable (along with the intake manifold)
The NB has a much better flowing head.
The bottom ends are fairly similar, but the NB runs higher compression.
green_comet
Car Detailing Guru
Postby green_comet » Mon May 14, 2007 8:33 pm
yeah the NB8A has a better flowing head, higher compression, and a different intake manifold. The intake manifold has butterflies in it the open up at a certain rpm creating better mid range torque. The engine also no longer uses a cam angle sensor..
I think you should sell it..
Rob E
Postby Rob E » Tue May 15, 2007 6:46 pm
NB engine also has solid lifters
