What are the remedies I should try?
Thanks as always guys
Derek
Juffa wrote:Are your upper and lower gear box seals still intact. Is there gear oil in the gearbox turret and if so is it reasonably fresh.
How is your clutch slave cyl. If worn it will leak fluid and makes smooth gear shifts difficult.
This is the easy stuff so check it first, if the above checks out ok then you may have to dig deeper.
J
