NA front swaybar help
lam.666
Postby lam.666 » Sat May 12, 2007 5:57 pm
just got the front swaybar off Rob E last night, installed it today but noticed that the left side of the swaybar rests on the upper arm.
driver side is fine with a 2 - 3 mm gap.
i used the bushes it came with, the OEM mounts and OEM links
when mounting the swaybar i wasnt able to adjust any movement of the ends and thought that after i let it down it might magically move in place.. but i was wrong
took it for a drive and it makes a clunking noise with every bump i go over
i think its a whiteline sway bar, does it matter which end goes where, i didnt actually check it for any left / right markings
any help appreciated
heres some pics
passenger side hitting upper arm
top view of passenger side hitting upper arm
driver side frontal
sort of top driver side
driver end links
passenger end links
Garry
Postby Garry » Sat May 12, 2007 9:09 pm
Try swapping it around left to right. I wouldn't drive it around like that though. You will damage the wishbones
lam.666
Postby lam.666 » Sat May 12, 2007 9:41 pm
yeah i was gonna try that tomorrow
see how i go, havent dríven it since going for that small test drive
Garry
Postby Garry » Sat May 12, 2007 10:07 pm
My workshop manual doesn't mention a left or right side. It might be an idea to take it off and compare it to the original bar to make sure it is the same shape and you dont have an NB bar, which will also fit with a few mods apparently.
Postby manga_blue » Sat May 12, 2007 11:35 pm
It often happens with NAs and that particular Whiteline swaybar. You need a set of shorter end-links. I've got a Whiteline set from Mossy sitting here that I didn't need because mine fitted OK. Almost unused with polyurethane bushes.
$35 inc postage. PM me.
lam.666
Postby lam.666 » Sun May 13, 2007 11:57 am
its the same on both sides, so i'll be needing those end links off you manga_blue
i've pm'd u and added u to msn
cheers
Postby bruce » Tue May 15, 2007 2:12 pm
Lam, your car is a japanese import? Just a guess cos I can see little bits of surface rust underneath (from the salted winter roads).
Astroboysoup
Postby Astroboysoup » Tue May 15, 2007 2:54 pm
i got the whiteline non adjustable front sway and its nothing like that it was a perfect fit
AustCars.net - It's like Facebook but for cars!
lam.666
Postby lam.666 » Sun May 20, 2007 10:57 pm
no its not an import
i thought the amount of surface rust for a car this old would be ok...
seems as though everyone who's fitted a 22mm bar has had no problems on an NA... i must be special
hopefully whiteline would be able to compare their bars with mine, or recommend on an endlink setup as the endlinks i got move the bar back and i cant screw in the mount
bigdog
King of the kennel
Postby bigdog » Sun May 20, 2007 11:26 pm
Could it be the wrong bar for the car - maybe an NB one or something?
Rob E
Postby Rob E » Mon May 21, 2007 9:41 am
I bought this one off Matty - came off his NA6 however i never fitted it because i have a Racing Beat hollow bar on the way. I have just PM'd Matty to see if he has any ideas........seems very odd indeed! :shock:
Matty
Postby Matty » Mon May 21, 2007 4:20 pm
Looking at the pics, your right upper control arm is bent to buggery. Fix it.
lam.666
Postby lam.666 » Mon May 21, 2007 8:55 pm
hmm ... doesnt look bent to me...
does it look like its bent to anyone else?
Rob E
Postby Rob E » Mon May 21, 2007 9:56 pm
lam.666 wrote:hmm ... doesnt look bent to me...
This very bar came off Mattys NA6 with no fitting probs.
Its either a bent control arm or the bar is bent - and the bar aint bent. I'd reckon the previous owner has put that car into the gutter or a traffic island.
lam.666
Postby lam.666 » Mon May 21, 2007 10:12 pm
yeah
bar ends are abit longer than the standard bar tho
guess i'll have to find another NA to test fit it to
too bad i missed out on the dodgy day
is anyone organising another one soon?
Users browsing this forum: No registered users and 239 guests
