Windscreen wiper inserts
meanmx
Postby meanmx » Thu Apr 05, 2007 5:29 pm
You can also clay bar your windows and it does the same thing as it does for the paint. Removes all the crap to allow for a smoother wipe.
Ben
2014 VW Mk7 Golf R
Daz 27
Postby Daz 27 » Thu Apr 05, 2007 6:31 pm
rjastra2 wrote:you need some of these....
that's what the new Aunger ones look like & they work great.
Alex
Postby Alex » Thu Apr 05, 2007 9:33 pm
normally a quick wipe of the blades every now and then will make them work like new again
I found a layer of oxidised/sun damaged rubber on mine is normally the culprit when they don't work properly, quick wipe over and all the black crud comes off and good as new :D
suzi
Postby suzi » Thu Apr 05, 2007 9:40 pm
come live in QLD - we don't need wipers!
Sunlight Silver 2002NB (Suzi)
AJ
Postby AJ » Thu Apr 05, 2007 10:10 pm
suzi wrote:come live in QLD - we don't need wipers!
WORD!!
we won't mention the last club run tho :wink: :lol:
XMX5 Rogues
idb000
Postby idb000 » Tue Apr 10, 2007 12:05 am
Thanks again guys for all the responses!!
2001 Black MX5 NB8B
http://www.idb000.com
Garry
Postby Garry » Tue Apr 10, 2007 7:28 pm
I tried out some of those new Aunger ones the other day. I tried 3 sets and none would wipe the passenger side propperly. They all missed a bit in the centre of the wiper blade. No idea why, so I took them back and got a refund.
idb000
Postby idb000 » Sat May 05, 2007 9:44 pm
Thanks again guys for all your advice. Things have been fairly busy, so I haven't had a chance to look at the wipers until today. I need to call on the collective wisdom of the Aus-cartalk community again. This may sound like a stupid question, but how do you get the existing wiper rubbers out? :oops: :oops: On previous cars when I have changed the wipers, there has been some form of clip you squeeze, which releases the rubber, and it slides out. On my current wipers, there is nothing like that. The 'captive' end of the rubber has a hole where the clip on the blade holds the rubber, but no way to release it (that I can work out) without breaking something. It looks like the wiper rubbers are the genuine Mazda ones, but I'm not sure. If anyone has any advice, that would be great! Here is a pic so you can see what I'm talking about:
Thanks again
Ian :D
2001 Black MX5 NB8B
Alex
Postby Alex » Sun May 06, 2007 1:10 am
not sure how much this will help but normally you can remove the metal strip parts of the wipers by just sliding them out leaving the rubber behind which can then be taken out
idb000
Postby idb000 » Mon May 07, 2007 10:13 pm
SM wrote:not sure how much this will help but normally you can remove the metal strip parts of the wipers by just sliding them out leaving the rubber behind which can then be taken out
Thanks SM. I had a look, but the metal strip won't come out easily (without breaking it at least). The rubber is held in the grooves by the 6 clippy type things (non technical name) on the blade, but the end one, as pictured above, sits into a molded slot on the rubber that doesn't appear to have an easy or obvious way of releasing it. :?
2001 Black MX5 NB8B
Garry
Postby Garry » Tue May 08, 2007 9:54 am
Just pull the end of the blade out of it's retainer thingo. It's rubber and pliable. You wont break anything. Once it comes out of it's retainer thingo slide it off the \"6 clippy type things things\" the same way you would normally remove a blade.
4sfed5
Vehicle: NA6 - Turbo
Postby 4sfed5 » Tue May 08, 2007 4:20 pm
ive now tried all sorts of wipers....the ones from supercheap were great at cleaning the screen but they squeeked like a mouse orgy! :mrgreen:
they lasted all of 8 hours in the car...i then bought some bosch ones and although they arent quite as good at wiping they are quiet!
idb000
Postby idb000 » Tue May 08, 2007 9:34 pm
Garry wrote:Just pull the end of the blade out of it's retainer thingo. It's rubber and pliable. You wont break anything. Once it comes out of it's retainer thingo slide it off the "6 clippy type things things" the same way you would normally remove a blade.
Thanks Garry. I'll have another try and see how I go.
2001 Black MX5 NB8B
Users browsing this forum: No registered users and 195 guests
