Build-up of the \"MX-7\" - Updated 19/5/07
lowmiata
Postby lowmiata » Thu May 03, 2007 2:07 pm
Dunno what they guy is worried about
the MX-5 gearbox is one of the easiest to remove!
only takes about half an hour!
just remember hwich way the engine will fall once you remove the gearbox
usually you can put a bit of 1/2 inch timber behind the engine against the firewall to stop the engine from scratching the paint
Might be different with the rotor though could fall forward then you would need totilt it back
Done alot of gearboxs on all sorts of cars and some really stupid ones the mx though would have to be the best!
EVI15 1998 to 2008
Boags
Postby Boags » Thu May 03, 2007 3:03 pm
1/2 an hour??? :shock:
I think you need to be present for the next clutch change I do! :x :lol:
SuperMazdaKart
Postby SuperMazdaKart » Thu May 03, 2007 6:12 pm
it's a Mazdaspeed NA6 LSD isn't it? probably a good thing to upgrade anyway
Boags
Postby Boags » Thu May 03, 2007 6:19 pm
SuperMazdaKart wrote:it's a Mazdaspeed NA6 LSD isn't it? probably a good thing to upgrade anyway
:shock: :shock: :shock:
Surely not??????
AJ
Postby AJ » Thu May 03, 2007 6:21 pm
Boags'MX5 wrote:1/2 an hour??? :shock:
LM probably removes all the bolts before he tries to get the box out tho boags :wink: :lol:
XMX5 Rogues
Boags
Postby Boags » Thu May 03, 2007 6:23 pm
It was hiding... :roll: :oops:
rhysk
Vehicle: NB8A - Supercharged
Postby rhysk » Thu May 03, 2007 6:40 pm
The upgraded Exedy clutch, with flywheel resurface and all seals, in my old NA, was $500 fitted -- and was done by a very reputable MX5 mechanic. At the time, I took it to mean that the clutch is fairly easy to replace.
Then last weekend I saw how much of a pain the job is :shock:
I've done the job on plenty of other cars, but I'm not going near a gearbox again in this lifetime.
supercharged NB (in Brisbane) - qr 1:01:75 (s), 1:05.90 (c)
jaguar xjr supercharged v8
Boags
Postby Boags » Thu May 03, 2007 9:36 pm
Surely not??????
they are better than a torsen.
The NA6 uses a 6" diff, the NA8 and up use a 7". The NA6 diff is useless when you throw power at it, regardless of what centre you put in.
The 1.8 housing is what you want. You could fill it with whichever type of LSD you want after that.
Boags
Boags
Postby Boags » Thu May 03, 2007 9:40 pm
We are thread swapping! :shock: :mrgreen: :lol:
PM Uncle Arthur. 8)
Boags
lowmiata
Postby lowmiata » Fri May 04, 2007 7:43 am
an hour if not on a hoist :D
there is only two bolts on the PPF
four for the tail shaft
two plugs
take the gear shifter off
and 9 i think bolts on the bell housing (don't quote me on that though)
drain the oil
then slide the box off!
if you have a good set of 1/2 inch extensions for your socket set it makes it ten times easier!
EVI15 1998 to 2008
JBT
Postby JBT » Fri May 04, 2007 8:30 am
lowmiata wrote:if you have a good set of 1/2 inch extensions for your socket set it makes it ten times easier!
.....and/or a rattle gun. 8)
jules
Guitar Hero
Postby jules » Fri May 04, 2007 9:54 am
IMHO you need a rattle gun and HEIGHT.
Jules
SuperMazdaKart
Postby SuperMazdaKart » Tue Jun 12, 2007 2:38 pm
isn't there a saying like \"can't have very quick with very cheap\" & \"can't have very reliable with very quick\"
Sean
Postby Sean » Tue Jun 12, 2007 6:05 pm
SuperMazdaKart wrote:isn't there a saying like "can't have very quick with very cheap" & "can't have very reliable with very quick"
I think it goes:
Quick - Reliable - Cheap
Pick 2...
JBT
Postby JBT » Wed Jun 13, 2007 11:26 am
A 1.8 Torsen change over would probably be cheaper. No parts need fabrication. Swap in 1.8 tailshaft, half shafts and diff - done. See MX-5 Plus for parts prices.
