Build-up of the \"MX-7\" - Updated 19/5/07
- lowmiata
Dunno what they guy is worried about
the MX-5 gearbox is one of the easiest to remove!
only takes about half an hour!
just remember hwich way the engine will fall once you remove the gearbox
usually you can put a bit of 1/2 inch timber behind the engine against the firewall to stop the engine from scratching the paint
Might be different with the rotor though could fall forward then you would need totilt it back
Done alot of gearboxs on all sorts of cars and some really stupid ones the mx though would have to be the best!
EVI15 1998 to 2008
- Boags
1/2 an hour???
I think you need to be present for the next clutch change I do!
- SuperMazdaKart
- Boags
SuperMazdaKart wrote:it's a Mazdaspeed NA6 LSD isn't it? probably a good thing to upgrade anyway
Surely not??????
- AJ
Boags'MX5 wrote:1/2 an hour???![]()
I think you need to be present for the next clutch change I do!![]()
LM probably removes all the bolts before he tries to get the box out tho boags
XMX5 Rogues
- Boags
AJ wrote:Boags'MX5 wrote:1/2 an hour???![]()
LM probably removes all the bolts before he tries to get the box out tho boags![]()
It was hiding...
- rhysk
The upgraded Exedy clutch, with flywheel resurface and all seals, in my old NA, was $500 fitted -- and was done by a very reputable MX5 mechanic. At the time, I took it to mean that the clutch is fairly easy to replace.
Then last weekend I saw how much of a pain the job is
I've done the job on plenty of other cars, but I'm not going near a gearbox again in this lifetime.
- Boags
lil_mike wrote:Boags'MX5 wrote:SuperMazdaKart wrote:it's a Mazdaspeed NA6 LSD isn't it? probably a good thing to upgrade anyway
Surely not??????
they are better than a torsen.
The NA6 uses a 6" diff, the NA8 and up use a 7". The NA6 diff is useless when you throw power at it, regardless of what centre you put in.
The 1.8 housing is what you want. You could fill it with whichever type of LSD you want after that.
Boags
- Boags
- lowmiata
an hour if not on a hoist
there is only two bolts on the PPF
four for the tail shaft
two plugs
take the gear shifter off
and 9 i think bolts on the bell housing (don't quote me on that though)
drain the oil
then slide the box off!
if you have a good set of 1/2 inch extensions for your socket set it makes it ten times easier!
EVI15 1998 to 2008
- jules
- Guitar Hero
- SuperMazdaKart
- Sean
SuperMazdaKart wrote:isn't there a saying like "can't have very quick with very cheap" & "can't have very reliable with very quick"
I think it goes:
Quick - Reliable - Cheap
Pick 2...
