Tow Hooks
Red Dragon
Tow Hooks
Postby Red Dragon » Tue May 01, 2007 5:31 pm
Just read an article that said the factory tow hooks were only for tieing the cars down during transit, and if used for actual towing this would do damage to the vehicle.
Is this right please ????????????
ducktape69
Postby ducktape69 » Tue May 01, 2007 5:46 pm
many people take them off(from the front of the car)...bit silly to tow from the front of the car on a RWD anyway
BLECK 2002 Mazda MX5 NB8B. Custom Heatshielded CAI . KYB AGX's + King Springs. 17\" Bleck Rims. Custom BASSSS Install.
SuperMazdaKart
Postby SuperMazdaKart » Tue May 01, 2007 6:40 pm
but if it's on a flat bed truck then i guess the hooks are useful for keeping the car attached to the truck
Andrew
Postby Andrew » Tue May 01, 2007 8:04 pm
SuperMazdaKart wrote:but if it's on a flat bed truck then i guess the hooks are useful for keeping the car attached to the truck
...or a tandem trailer -
irwin83r
Postby irwin83r » Tue May 01, 2007 8:41 pm
or if youve gone ass first off the road and are bogged in a ditch.... dont ask me how i know this but they do work to pull you out of ditches :oops:
Red Dragon
Postby Red Dragon » Tue May 01, 2007 9:07 pm
Thanks irwin83r you have proved that the article was just a heap of yank crap then and the hooks do work without harming the car
irwin83r
Postby irwin83r » Tue May 01, 2007 9:10 pm
:oops: :roll:
JBT
Postby JBT » Tue May 01, 2007 9:21 pm
As I recall, the owner's manual states that they are tow points.
lowmiata
Postby lowmiata » Wed May 02, 2007 1:52 pm
They will do damage to the car if you don't use them correctly
I removed mine years ago
And every time I have to call a tow truck i have to specify a 40ft long or longer tow truck as you have to put the salvage hooks all the way down under the front lower A arms!!
and with a bigger front bar the wilre/chain hits the bottom of it
if I still had them I would use them all the time!
if you do use them make sure when you pull the car it is from directly in front or directly behind otherwise you will do substantial damage
main reason (on the front) is the only front cross rail is the top radiator support, there is no other structure to support the tow hooks if towing from the side in a recovery situation.
EVI15 1998 to 2008
jules
Guitar Hero
Postby jules » Wed May 02, 2007 4:50 pm
Pull the teeth. They look disgusting.
Jules
CT
Postby CT » Wed May 02, 2007 5:34 pm
The hooks are that substantial that we simply extend them by welding longer hoops onto them and bolt them back on to the race cars. They are plenty strong enough and I have been towed out of kitty litter well over the sills by them.
However, if you are towing the car on a trailer all the time, the front suspension/wheels are a much better solution. 8)
Users browsing this forum: Bing [Bot] and 3 guests
