Rims and wheel nuts
Slugoid
Rims and wheel nuts
Postby Slugoid » Tue Apr 24, 2007 7:25 pm
I recently purchased these rims for track:
Stock MR2 Spyder rims. Problem I'm facing now is that the holes on the rims are perfectly flat and my wheel nuts are tappered. Illustration below:
I've ran one track day with the tappered nuts and it was ok but it seems like inside edges where the wheel and nut touch are getting a tad worn. I've seen stock Toyota wheel nuts and they seems sit flat on the rims with some washer over it.
Do you reckon it's safe running my current setup, or better if I actually got Toyota MR2 wheel nuts (12 X 1.5). Does stock MX5 wheel nuts have a flat base too? Any other alternatives?
zoomzoom
Vehicle: NA6 - Turbo
Postby zoomzoom » Tue Apr 24, 2007 8:07 pm
Thats just like most old school wheels, they are designed to be used with a different type of nut. It is a straight shanked nut.
A special conical washer is available to use std wheelnuts. I don't know where else they are available but I think performance wheels used to make them.
Tim
PUR157
Postby PUR157 » Tue Apr 24, 2007 10:36 pm
Where did those wheelnuts come from?
My friend recently got some aftermarket wheelnuts for his car and had a similar problem...
It was pointed out to him that the wheelnuts he was using were supposed to be used with aftermarket (or JDM) rims...
Problems? shouldnt be TOO bad on the roads... if they dont jiggle about theyre as good as safe... thats not to say that theyre holding the wheel properly... they probably arent stressed enough to be dangerous
the best solution would be to find proper fitting wheelnuts... (the normal flat bottome ones? werent those the universal fitment?)
Oneness of Man and Machine
zoomzoom
Postby zoomzoom » Tue Apr 24, 2007 10:43 pm
I would reccommend NOT using those nuts with those rims at all, as alluminium alloy is very soft and as you say begins to wear, not good at all, and definately not safe. If you go to any tyre shop you should be able to get the old school type nuts and washers to fit the 5(I think they are just a std 12x1.5 thread at a guess)
You may also need to ream out the holes with something to remove the 'worn' bit from around the holes so the proper nuts will get through too.
Hope this is some help, Tim
ben wilson
Postby ben wilson » Wed Apr 25, 2007 12:13 am
Go for the genuine Toyota ones - Just make sure you're sitting down when you find out how much they cost....
zoomzoom
Postby zoomzoom » Wed Apr 25, 2007 12:15 am
What is so good about the gen toyota ones? The last time I got a set of chrome ones from the tyre shop they were a couple dollars each and were fine
irwin83r
Postby irwin83r » Fri May 18, 2007 6:39 pm
no need to go toybota ones. just buy ones that fit your studs and the rims from a tyre or wheel shop if they dont have them they will most likly know someone that will. but i would be listening to Mr zoomzoom here and getting these studs asap if i was you :shock:
Slugoid
Postby Slugoid » Fri May 18, 2007 11:15 pm
irwin83r wrote:no need to go toybota ones. just buy ones that fit your studs and the rims from a tyre or wheel shop if they dont have them they will most likly know someone that will. but i would be listening to Mr zoomzoom here and getting these studs asap if i was you :shock:
Yeah, I'll be looking at proper nuts before I use the rims next time. After all, they are my track rims and I don't use them unless I need to :)
GP
Postby GP » Mon May 21, 2007 10:51 am
Lug Nuts? Bloody Americanisms :lol:
Graham
Slugoid
Postby Slugoid » Mon May 21, 2007 11:14 pm
GP wrote:Lug Nuts? Bloody Americanisms :lol:
Fixed :lol:
I never knew lug nuts was an American term. Think I'll stick with wheel nuts from now :P
Users browsing this forum: Google [Bot] and 194 guests
