Camber for semi slicks
kula
Postby kula » Fri Apr 13, 2007 10:53 pm
i run -3 on the road all round.
no problems.
StanTheMan
Postby StanTheMan » Sat Apr 14, 2007 1:55 am
I'n not quiteas bad as Kula.
-2.5 front -2.25 rear.
but its been about a year since mylast allignment.
:roll: so it could be anything.
rhysk
Vehicle: NB8A - Supercharged
Postby rhysk » Sat Apr 14, 2007 3:53 pm
I run -2.7 camber
Street tyres are RT615, they are wearing evenly
Track tyres are Kumho V700
Both at 36 hot.
supercharged NB (in Brisbane) - qr 1:01:75 (s), 1:05.90 (c)
jaguar xjr supercharged v8
Cal
Postby Cal » Fri Apr 20, 2007 12:10 pm
rhysk wrote:Both at 36 hot.
You might want to try bringing the semis down to more like 29-30 hot.
Cal.
Boags
Postby Boags » Sun Apr 22, 2007 10:21 am
I have read that lower pressures will give you more initial grip, but turn off like a light when they do go. Higher pressure will have less initial grip but be more progressive. Setting your pressures higher for beginners would seem to be a good idea, and lowering them as you get better.
I run 28-30 cold in my R888s and find that is nice and progressive when hot, but still sticky enough to hold in the corner. I don't carry enough corner speed though, so if I was pushing it harder it might be a different story.
Please correct me if you know otherwise.
Boags
Cal
Postby Cal » Mon Apr 23, 2007 2:50 pm
There are loads of variables. Obviously we are running -3 degrees or more camber if we can get it. Very agressive caster and bushes with little or no compliance. We would also get less chassis flex with the side intrusion bars and diagonal cockpit bar. Boags is correct in that the higher the pressure the more progressive they are, but they wear quicker too. I start at about 24psi cold and bring them up to about 30psi hot. As the day gets hotter I may need to let a little more out at some point. Very different from a road tyre in the pressure department.
Cal.
StanTheMan
Postby StanTheMan » Tue Apr 24, 2007 9:02 am
you could get an adjustabble camber bush kit.
talk to boy racer.
Cal
Postby Cal » Tue Apr 24, 2007 10:35 am
Yep Stan is onto it. We use offset lower control arm bushes. They only seem to give about -3 though. There are ways to get more again, but I've not tried them.
Cal.
Charlie Brown
Postby Charlie Brown » Wed May 09, 2007 3:32 pm
Very interested reading the above comments following my first outing on DOT tyres on Monday.
I started with 26psi cold and found the tyres were warmed up after almost a lap of Wakefield.
I used this first series of laps to test out the limits of the tyres and to see what happened when they let go. I found them to be very progressive with plenty of time to dial in steering changes to correct any slip.
The second session I had a bit of a go and managed to record what ended up my FTD. I didn’t check pressures thinking that I had the balance just right.
Third session I managed to get myself out first in the group and thought I had the hang of the tyres so really put the boot in but the times didn’t reflect the expended effort. So I checked the pressures. The rears were running 33 hot and the front left 38+psi and the right 36psi. Obviously more work was being done on the left side because it’s a clockwise circuit and the car tended to understeer due to my tyre size combination.
So I dropped the fronts to 33psi and went out for the six lap regularity. Track temperature had risen by this time and my times were still slower than the second session.
For the last run of the day I dropped the pressures to 30psi rear and 31psi front. The tyres complained on some corners, and I’m not sure if DOT tyres are supposed to squeal or not, however the times were quicker and apart from the first lap the next three were within 0.3 second of my best lap. Maybe someone can let me know if DOT tyres squeal.
For the record I‘m running 2 degrees negative F & R with 16x8 rims fitted with old, well used 205 V700 Kumho’s on the front and 225 Dunlop D01Js on the rear.
Next time out I hope to have some fronts to match the rears. Then with a bit of tweaking maybe this almost stock NC can loose half a second and drop into the 1:12s :D
Cal
Postby Cal » Wed May 09, 2007 4:58 pm
Yeah they can squeal, but really shouldn't. I found they did on the green car because it didn't have enough negative camber. Was about -2 like yours. Also an indication that the pressures might be a psi or 2 too low. From memory, i think they'll squeal if over inflated a LOT (like 40psi) too.
Cal.
Charlie Brown
Postby Charlie Brown » Wed May 09, 2007 5:04 pm
Thanks Cal, next time I'll try 32 hot and see what happens.
Ted
Postby Ted » Wed May 09, 2007 7:07 pm
One important factor here is number of heat cycles. When running older rubber, I generally found that they come up pretty quick and then go away pretty quick too. Doesn't seem to have that much to do with tyre pressures at that point. New tyres which are run in nicely seem to be more consistent than those which I bought as used tyres. Compounds also made a difference.
BTW I still use a guide of 36hot as a starting point, fine tune from there. On a track day, it may mean bleeding air out all day as they never really get cold enough from a pressure point of view. And its quite amazing how much pressure they can drop in that one in lap.
Mind you, I am no circuit racing guru, I must get bored or dizzy!
Motorsport is a disease, where the only cure is poverty!
The ego writes cheques that skill can't cash - DJ
irwin83r
Postby irwin83r » Mon May 28, 2007 8:22 pm
OT but how would you run tyres in nicely??
other than that. im getting my post offset bush install alignment done tomorrow and i was thinking the following specs for an NB8A N/A on semi slicks.
front
caster: max caster
camber: -3.5
toe: 0.05-0.1 toe in
rear
camber:-3.25
toe: 0.05-0.1
anyone got any thoughts or suggestions??
irwin83r
Postby irwin83r » Tue Sep 04, 2007 12:39 am
are alignment settings a really well gaurded seceret or something??
StanTheMan
Postby StanTheMan » Tue Sep 04, 2007 9:07 am
irwin83r wrote:are alignment settings a really well gaurded seceret or something??
no just that there is 1000 ways for allignment setting & 100 000 different opinions.
people like CT. started with the basics. then he went out there mucked around & has worked it out himself and has become an authority on it. Theats what most racers have done.
Return to “MX5 Motor Sport”
