help! removing aircon compressor - bolts stuck
Fatty
Postby Fatty » Wed Apr 18, 2007 8:13 pm
i'm trying to remove the aircon pump / compressor thing from the front of the engine. it's held on to the bracket by 4 bolts / screws. got the top 2 loose eventually, with a bit of wd40. can't get the bottom 2 to budge tho. they are stuck tight :(
any tips here guys? i've been trying and i've started to round off the edges on one the bolts so i'm gonna give up for now until i have some new method to try.
also, had a look at the belt that drives it and it's in really bad shape! chunks torn out of it etc. suppose i shoul get a new one eh? any tips in fitting the new belt ?
Boags
Postby Boags » Wed Apr 18, 2007 9:02 pm
1. Glad to see you have lost your skirt and started to get the ball rolling. :lol: :mrgreen:
2. Have you removed the undertray to attack those two bolts from the bottom? That's how I got to mine.
3. Have you got power steering? If you do, I don't know how to change the belt. If you don't, undo the 14mm nut on the front of the tensioner pulley and then unwind the 10mm bolt on top. Easy.
So, does this mean you are drilling the sump? 8) :mrgreen:
Fatty
Postby Fatty » Wed Apr 18, 2007 9:54 pm
yeah i took the undertray off. i still can't get the bolts to move, even from under the car.
i don't have power steering. thanks for the tip, sounds easy enough. just gotta get a new belt then!
mate, check your messages!!
meanmx
Postby meanmx » Wed Apr 18, 2007 10:51 pm
Sounds exciting Fatty. Can't wait to see it.
Ben
2014 VW Mk7 Golf R
sabretooth
Postby sabretooth » Tue Apr 24, 2007 12:54 am
Is it that the bolts won't spin?
Have you tried more leverage from a tube or breaker bar? They're very long bolts so you'd have to mistreat them quite badly to snap them.
Fatty
Postby Fatty » Tue Apr 24, 2007 7:49 am
yeah i got them off eventually with a bit of force and some wd40.
