Fatty wrote:whaddaya mean the stock pump won't run them? you mean it won't be able to supply enough pressure to get me up to 150kw ? or it won't run them full stop ? coz it is running them fine right now (not boosted yet tho)
if you have fitted prog ECU
and have fitted the injectors yes they will work boosted or not
once you up the boost/duty cycle on the injectors the pump wont be able to supply the demand
the factory pump might beable to supply for 150kw but it would near the end of its usability and if something went wrong as its being maxed out it could be catistrophic
mines doing fine at 125 though
would be worth finding out if no one has its usability range.?
