Brown Davis Padding..
green_comet
Car Detailing Guru
Postby green_comet » Tue Apr 03, 2007 12:09 pm
Hi guys,
I just wanted to know which padding people suggest for a Brown Bavis bar.
I wanted to get some padding as im a little worried having a metal pipes soo close to my head..
cheers
Ryan
Boags
Postby Boags » Tue Apr 03, 2007 1:11 pm
I thought the idea of BD was to stop you from worrying?! :roll:
zoomzoom
Vehicle: NA6 - Turbo
Postby zoomzoom » Tue Apr 03, 2007 2:21 pm
I had padding on mine to get a mod plate and took it off because it impairs rear vision even more. My head is quite a bit lower than the bar though and fairly forward(I'm not that tall). The padding I did have on it was just from a foam and rubber shop and about 20mm thick(QLD DOT says 19mm high density) and alot of cable ties :D
Postby manga_blue » Tue Apr 03, 2007 3:03 pm
Revolution Racegear at Mitcham have a range of padding, plus advice.
StanTheMan
Postby StanTheMan » Tue Apr 03, 2007 3:03 pm
get some NB8B seats. They are quite high......although hitting your head on the roll bar is probably still possible, the danger is reduced a fair bit.
green_comet
Car Detailing Guru
Postby green_comet » Tue Apr 03, 2007 3:14 pm
I have a aftermarket bucket for the driver, and it protects my head no worries. When my girlfriend sits in the passenger seat she sometimes hits her head on the bar. :?
She is 6ft tall so that why im interested in getting padding. I would much rather spend a few doller on some padding, then spend god knows how much on an NB seat. Good idea though.
Boags
Postby Boags » Tue Apr 03, 2007 3:21 pm
green_comet wrote:...my girlfriend...is 6ft tall
Nice work! :mrgreen: 8)
Grumpy
Postby Grumpy » Tue Apr 03, 2007 9:00 pm
If anyone is interested, I can supply 2m lengths of padding for $20 and zip ties to suit @ $0.45 each. Colours may vary from time to time but normally have Blue, Orange, Red, Yellow, Green and Black.
Factory is in Craigieburn Vic.
Sadly MX5 less for a while.
Rebuilding an 89 Honda CRX
StanTheMan
Postby StanTheMan » Tue Apr 03, 2007 9:36 pm
green_comet wrote:I have a aftermarket bucket for the driver, and it protects my head no worries. When my girlfriend sits in the passenger seat she sometimes hits her head on the bar. :?
NB8B searts will be $800 for a pair upwards. Padding is the proper way to do it.
bigdog
King of the kennel
Postby bigdog » Tue Apr 03, 2007 11:23 pm
Have had two goes at this so far, not happy with either :roll: I have used the HD roll bar foam from Revolution Racegear (same stuff Grumpy is offering, and his price is better). My problem is that I hate cable ties and the effect they have on the foam (looks like a bunch of sausages to me). My next attempt will entail a visit to a rubber store ( :shock: not the ones on Oxford St :roll: ) to look for some suitable tubing and then enclose this in some form of upholstered vinyl or wetsuit rubber to conform to the curves of the bar properly. Ultimately not quite as effective as the foam, but easier to live with. The roof frame really dents the foam when you put it up too - 20mm is too big on top of the bar.
Inf3ct0R
Postby Inf3ct0R » Tue Apr 10, 2007 9:26 am
Bevan
Postby Bevan » Tue Apr 10, 2007 6:06 pm
You should probably cover the middle bit too...
Return to “MX5 Motor Sport”
Users browsing this forum: No registered users and 92 guests
