deleted
- Craig
- Vehicle: Non MX-5
Castrol Synthetic will do the job perfectly, but put a sacrificial cheap one in first to 'cycle' out the crap into it, and then put in the Synthetic.
*** Audi Q5 55 Sportback - HYBRID! Zero -100 in 5.3 seconds!
- Craig
- Vehicle: Non MX-5
If you can get it cheap enough just use the Castol Synthetic, not sure on pricing myself.
Run it for 5000 klms to really cycle the grit and muck out. In my NA I ended up flushing it 4 times in total to get rid of the notchy/grinding and at the last attempt it was like a hot knife through butter...Matt can attest to that!
Done it twice on the NB8B and will do it again at the 50K service.
- Craig
- Vehicle: Non MX-5
I don't think there's an exact science really but I think 5000klms is a good point to pull the oil and do it again, it's what I just happened to do as I'm a fussy bugger and pondered that if the first time improved the shift, what'd happen successive times after that? I just stopped at 4 as it was mint after that.
Bear in mind I'm no mechanic but!
I had the Redline oil, for the gearbox and diff, rags, coffee, cola, snackes,etc and ready to jump in......
Man, this car is seriously low......can't even see where the drain and fill plugs are!!!
How do you guys raise the car high enough (safely) to crawl underneath? You may not appreciate how difficult it is if you wear glasses as they keep falling off! B*sta*d !!!!
So I've finished the coffee and cola and the snacks but done f-all !!!
I'm a good DIYer, but not good if I can't get to the plugs!!!!
franjae
franjae
NC sold, but will return one day.......
- Alex
franjae wrote:How do you guys raise the car high enough (safely) to crawl underneath? You may not appreciate how difficult it is if you wear glasses as they keep falling off! B*sta*d !!!!
a jack and some proper stands generally does it for most
if the cars too low then
http://www.graysonline.com.au/lot.asp?LOT_ID=1398293
and stands
http://www.graysonline.com.au/lot.asp?LOT_ID=1398284
Never work under the car that's just supported on a jack always have it on proper jack-stands
- Craig
- Vehicle: Non MX-5
franjae wrote:I wonder if the missus will notice an inspection pit in the garage? Should I start digging??![]()
Yes but do your own grave first!
- Craig
- Vehicle: Non MX-5
Cycling the fluid makes sure all the rubbish is gradually removed with each subsequent oil change. With every change I did on the NA the less gunk/metal shavings there were floating around in the oil and it could do it's job properly without grinding and carrying on. The first oil change was done at 43,000klms and the oil on removal was putrid and gluggy...scary huh for such low klms!
The bush on the bottom of the shifter looks like this
Good reading found here >>> http://www.miata.net/garage/trans/everything.html
