Cat convertor for turbo - metal or ceramic core and why?
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
From those who've gone turbo - do you use a ceramic or metal core cat convertor, and for which one, why?
I use a metalcat cat convertor, it pretty exxy at about $350 but from the searching I did on google it seems to be the best there is.
70 240z done!! Well almost.
http://www.viczcar.com/forum/index.php/topic,4438.0.html
- 16bit
- godfather of saké
I've got as metal cat on the rotary. If you pick one up and hold it against the light, you can pretty much see thru it, so they must flow well. Also the metal substrate is stronger and can withstand heat from the turbo better, so that this doesn't happen (which is a non-metal cat that was in my car...who said rotaries are hard on their cats!):
- ASE05
