First steps were to get two 300zx coolers and make one good one out of two!
next steps were as followed
dummy up where i roughly wanted the cooler to fit and just make up all the pipe work
and this is the bracket that now holds the throtle cable
the inter cooler tanks have a few mounting point on the now what is the under side that you could fit other stuff to if wanted
The intercooler isn't very heavy at all, hence not mounted to the body at all and doesn't move other than with the engine
Of particular note is the intercooler i \"adjusted\" would be absolutly perfect for an MX-5 with two inch outlets on either side!
Putting a GU bonnet scoop on this coming weekend to get full benifit from the intercooler
