Hardtop brackets to hold soft-top down
Gazbo
Postby Gazbo » Fri Mar 30, 2007 8:19 pm
My newly aquired hardtop has those brackets inside under the rear window that are obviously designed to press down on the folded soft-top catches to stop the soft-top moving.
Trouble is, the brackets sit around 20mm above the soft-top catches, and don't contact the soft-top at all.
Is there something wrong with my top, or are they all like that?
Daily: 2006 "C" Mazda3 SP23
Fun: 1993 NA6
Mr_Q
Postby Mr_Q » Fri Mar 30, 2007 9:46 pm
They're all like that. They're not really supposed to hold the soft-top down (it doesn't bounce around that much with the hardtop off, does it?), more just to stop the soft-top latches rattling against the hardtop.
Mister Q
Had: Red 2004 SE, Red 1993 NA8 Clubman, Green 1991 NA6 LE
Gazbo
Postby Gazbo » Fri Mar 30, 2007 11:01 pm
Thanks Mr_Q.
The soft-top doesn't bounce around much, it just makes a lot of squeeking noises.
