Show us your struts ..
- Lucky_Luke
How low is your MX?
Hey everyone I've seen on a few other forums people listing their suspension setups. I thought it would be interesting for everyone to list the details of their suspension for others to see and compare if they are considering changing their set ups, or lowering their cars.
Heres mine..
Model MX - 1990 NA
Front Springs - King Springs
Front Struts - KYB Non Adj
Rear Springs - German Hot Bits
Rear Struts - KYB Non Adj
Front Sway bar - Whiteline Non Adj
Rear Sway bar - Whiteline Non Adj
Ride heights (from the ground to the top of the wheel arches)
Front - 580mm
Rear - 600mm
Rolled guards? - Front only
And a picture -
Luke
Heres mine..
Model MX - 1990 NA
Front - 580mm
Rear - 600mm
And a picture -
Luke
- lowmiata
Model MX - 1990 NA
Front Struts - Monroe gas thingies!
Rear Springs - King springs
Rear Struts - Monroe gas thingies!
Front Sway bar - stock
Rear Sway bar - stock
Front - not much
Rear - even less than the front!
Rolled guards? - Front ones wer done but have pulled them out a little so the panel wont get damaged when leaned on
rears just pushed up alittle and duburred
and a pic
suspension is doing quite well for the extra 30-40kg's of stereo gear in the back!
Front - not much
and a pic
EVI15 1998 to 2008
Model MX - 1992 NA
Front and Rear coilovers - Tein Flex
Front Sway bar - Whiteline Adjustable (softest setting until I get adjustable end links)
Rear Sway bar - None
Ride heights (from wheel centre to the bottom edge of the wheel arches)
Front - 335mm
Rear - 325mm
Rolled guards? - N/A
Bushes - Superpro
Front - 335mm
Rear - 325mm
Bushes - Superpro
- godfather of saké
MX-5 Clubman NA8
Front & Rear Springs - Tein Super Street, JDM rates: 330/275
Front & Rear Shocks - Tein Super Street w/ EDFC in cabin adjustment
Front Sway bar - Stock
Rear Sway bar - Stock
Ride heights (from the wheel centre to the top of the wheel arches)
Front - 325mm
Rear - 325mm
Rolled guards? - Front and rear
Bushes - Stock
- adamjp
Model - 1991
Shocks - Koni Sport
Springs - Eibach (Centre perch)
Sways - Stock for now
Front height - 585mm (~300mm from centre)
Rear height - 585mm
Rolled Guards - Nope
Bushes - Stock for now
Shocks - Koni Sport
Rear height - 585mm
Adam
- zoomzoom
- Vehicle: NA6 - Turbo
- SuperMazdaKart
Model MX - 1994 NA8 Clubman
Front Struts - Clubman Bilsteins
Rear Springs - King Springs
Rear Struts - Clubman Bilsteins
Front Sway bar - Stock Clubman
Rear Sway bar - Stock Clubman
Front - 580mm
Rear - 595mm
Rolled guards? - Rear only
Front - 580mm
Rear - 595mm
- godfather of saké
Model MX - 1989 NA
Front Springs - Tein Super Street
Front Struts - Tein Super Street
Rear Struts - Tein Super Street
Front Sway bar - OEM
Rear Sway bar - OEM
Front - not sure (320mm from wheel centre to arch)
Rear - not sure (325mm from wheel centre to arch)
Rolled guards? - nop
Rear Sway bar - OEM
- SuperMazdaKart
- StanTheMan
- zoomzoom
Users browsing this forum: No registered users and 209 guests
