HELP!!! NA Pop-up headlight NOT poping up!
Mr Starlet
Postby Mr Starlet » Sun Mar 11, 2007 11:00 pm
Russellb wrote:That is not the same wiring diagram I have. I have the Mazda Australia
book . for both the 89 NA and the 95 NA, there is a differance for the 2 models.
will take a Pic of the pages and post them up tomorrow
Awesome!!
zoomzoom
Vehicle: NA6 - Turbo
Postby zoomzoom » Sun Mar 11, 2007 11:22 pm
Don't bother with the US diagrams, the Aussie ones are different, and after looking around I think the imports are different too. The very early Aussie delivered cars have it located under the dash on the same bracket as the indicator flasher can. I think the imports have some door buzzer thingy in this place though.
Good luck :D
JBT
Postby JBT » Mon Mar 12, 2007 7:01 am
The diagram I posted is from the 1990 Mazda (Japan) MX-5 Workshop manual.
I pulled the tail light fuse on my 1995 and the headlights and pop ups work normally with it removed. I doubt there would be any difference for the pre-1995.
Mr Starlet
Postby Mr Starlet » Mon Mar 26, 2007 4:21 pm
Ok, still can't find the retractor relay :evil: , I'm sure someone out there with Aussie or Jap MX who would have had to replace one in the past. I found the \"Retractor\" fuse but no the relay.
JBT
Postby JBT » Mon Mar 26, 2007 4:55 pm
Have you had a good look around under the dash as suggested by zoomzoom? I believe it's under there somewhere.
Mr Starlet
Postby Mr Starlet » Mon Mar 26, 2007 5:13 pm
JBT wrote:Have you had a good look around under the dash as suggested by zoomzoom? I believe it's under there somewhere.
I'll have a better look but so far couldn't find anything under there that relates to headlights.
JBT
Postby JBT » Mon Mar 26, 2007 5:17 pm
Look for a small plug/box with the following wire colours attached/plugged in:
red/green
white/black
black
red/yellow
white/red
Mr Starlet
Postby Mr Starlet » Mon Mar 26, 2007 5:24 pm
pics still coming Russellb?
Russellb
RIP Nov 2014
Postby Russellb » Mon Mar 26, 2007 8:27 pm
:( Sorry about the delay .
Anyway had a look at the diagrams and the tail light fuse does just that ( run the tail lights )
Here are the NA8 diagrams
My ClubmanRebuild
MX5 SE Rally car is HERE :)
Russellb
RIP Nov 2014
Postby Russellb » Mon Mar 26, 2007 8:38 pm
And The NA6
My ClubmanRebuild
JBT
Postby JBT » Mon Mar 26, 2007 8:43 pm
That diagram is precisely the same as the ones posted on page one by Kitkat and myself :? However, the relay is not in the engine bay of Australian (or Japanese?) market cars.
Mr Starlet
Postby Mr Starlet » Mon Jun 11, 2007 10:24 pm
Hey all, finally figured out that pop-up headlight issue. Please see details, you might find it useful at some stage.
On my 89' Import NA
Retractor relay is in engine bay, passenger side.
On my 91 Aussie NA
Rectractor-relay was found underneath steering column mounted on the same bracket as the flasher/indicator relay...thanks for the heads-up zoomzoom
inspect solder joints and tracks for stress and reflow if required...
You can see the cracks on mine, I reflow reassemble and it's like new again.
JBT
Postby JBT » Tue Jun 12, 2007 7:58 am
Well done Minh. The hardest part is actually finding that relay. :roll:
Oldfart_mx5
Re: HELP!!! NA Pop-up headlight NOT poping up!
Postby Oldfart_mx5 » Thu May 12, 2016 6:19 pm
And here years later another bunny has been looking for the retractor relay and ya hoo after reading the above I finally found mine also under the steering wheel. Keep up the communication it helps more than you think. Now I can have a beer.
pcmx5
Postby pcmx5 » Thu May 12, 2016 10:41 pm
I think you will find if you read the manual the Mazda advises using the pop up light switch rather than the headlight control to raise the lights.Not sure why it makes any difference but apparently enough to warrant a mention.Hope all goes well,
Peter.
