dyno tune done, 167RWKW!
Looks like my car is finally finished and ready to be dríven, just got the call from the tuner and the results are 167 RWKW, not bad for a 1.6, can't remember what boost we ran but I think it may have been 13 or 14psi. I will post up the dyno sheet when i pick up the car.
70 240z done!! Well almost.
http://www.viczcar.com/forum/index.php/topic,4438.0.html
- Boags
Awesome. That is well over the stock power figures. It'll be a beast to drive, I'm sure!
Well done! Post the dyno chart when you can.
As far as I know it only has forgies, didn't really get a chance to test the car this morning as its still damp but I could tell straight away how responsive it was.
- Astroboysoup
- Astroboysoup
bruce wrote:Wow Astro - sex change and a new job as a comedian!
thanks bruce
AustCars.net - It's like Facebook but for cars!
Well its interesting to drive, 1st and 2nd are useless with the standard wheels, they just spin, 3rd seems to be where you can put the power down but thats only if its totally dry. I don't think I'll be driving this in the wet its just too sketchy, when I picked the car up it was damp and you couldn't even use half the throttle without getting sideways.
After going for a drive today it looks to be running at 12psi not 14psi, even better
- StanTheMan
..Astroboysoup wrote:here's my dino chart
ROFLMHO.....Now that is funny.
Great results Mossy.
I drive mine in the wet a bit and I am making ~160rwkw. It will wheelspin at will, even in fourth, but it is very easy to keep traction if you drive accordingly.
You have a boost controller already, it is called your right foot. You can't get high boost unless you open the throttle, it just doesn't happen.
Jake
Jake
- Fuzzlet
I'm running just over 190kw @14psi, and mine is fine in the wet. Its all about throttle control. It was a bitch to get used to at first tho
