Exhaust Manifold Question
- green_comet
- Car Detailing Guru
- Sean
Bevan wrote:Sean wrote:Stay away from maniseal - it is the devils glue.Please explain?
It doesn't really serve a purpose if you have a proper gasket. Everytime I have used it it decintergrates, maybe due to excessive heat?
- Bevan
Ahhh, possibly. It says it can stand up to 300*C. If you used it on the turbo would it get hotter than that? Could be reason.Sean wrote:Bevan wrote:Sean wrote:Stay away from maniseal - it is the devils glue.Please explain?
- Sean
Bevan wrote:Ahhh, possibly. It says it can stand up to 300*C. If you used it on the turbo would it get hotter than that? Could be reason.Sean wrote:Bevan wrote:Sean wrote:Stay away from maniseal - it is the devils glue.Please explain?
I'm sure my EGTs would be over 300*C at teh manifold even NA...
Am I wrong?
Re: Exhaust Manifold Question
Sorry to bring up the dead, but I just went and got a manifold gasket from auto1, and there are two in the packet, both the same silver fabricy material. Does one of these replace the metal mazda gasket, or do both of them, or do i put one of them on with the mazda metal gasket??
