Drilled Brake Rotors
lil_mike
Postby lil_mike » Wed Mar 21, 2007 4:35 pm
hi guys,
i was thinkig about this the other day. my car has slotted, vented and drilled rotors on the front. now i've heard that you should never run drilled rotors on road as they break easily? is this true? if so, then why do all the FPV vehicles like the F6 typhoon and such all have the same, and lets face it, they need a lot more braking power than my car to slow that much weight.
opinions?
kitkat
Postby kitkat » Wed Mar 21, 2007 4:48 pm
i think its only dangerous if they were drilled after manufacture.
If they were produced like that from the factory then they should be fine as they have taken the drill holes into consideration with the design.
(does that make sense? :? :oops: )
lil_mike
Postby lil_mike » Wed Mar 21, 2007 4:53 pm
kitkat wrote:i think its only dangerous if they were drilled after manufacture.
they were installed pre-drilled, so they were built like that. so yes it does make sense :lol:
apparently as long as they arent subjected to extreme applications they should be fine? thats what wikipedia says anyway, would like someone experiences though.
CT
Postby CT » Wed Mar 21, 2007 9:12 pm
On the road it is purely for bling factor. On race cars, where brake temps can easily exceed double what you will see on the road, they can tend to promote cracking. But, as race cars replace rotors often and most don't even use drilled rotors anymore, it's nothing to be worried about for the road. If you stick it on the track, be careful to inspect them regularly - both rotor faces.
Boags
Postby Boags » Wed Mar 21, 2007 11:39 pm
The only time I have heard of them failing is on Porsche GT3s doing several 250km/h-0km/h stops in a row. I can't see an MX5 ever replicating those conditions...
Boags
lil_mike
Postby lil_mike » Thu Mar 22, 2007 7:59 am
Boags'MX5 wrote:The only time I have heard of them failing is on Porsche GT3s doing several 250km/h-0km/h stops in a row. I can't see an MX5 ever replicating those conditions...
Boags
hmmmm, boags, its a rotary and its me driving :lol: i dont know about that?
it will be tracked and dríven hard fairly often. what should i look for specifically on the rotor faces?
Boags
Postby Boags » Thu Mar 22, 2007 9:05 am
Boags
I doubt there is enough room anywhere for you to get up to 250 more than a couple of times, and if you do, I doubt you'll be thinking "I wonder how long it'd take to stop from this speed."
You should be looking for hairline cracks, warping or anything other than clean straight surfaces I suppose.
Boags
PS - When are you going to invite me round for a beer so I can see the beast? 8)
kitkat
Postby kitkat » Thu Mar 22, 2007 10:50 am
Boags'MX5 wrote:PS - When are you going to invite me round for a beer so I can see the beast? 8)
X 2 :P
Benny
Postby Benny » Thu Mar 22, 2007 11:27 am
If the holes are actually cast into the rotor, they are fine, but if they are drilled after the disc is cast, then they can start cracks as the drilling stresses the metal.
During expansion and contraction (heating up and cooling down) the holes get bigger then smaller, and this causes a lot of the stress.
Just stick to slotted rotors and forget about the holes.
They don't do all that much anyway.
lil_mike
Postby lil_mike » Thu Mar 22, 2007 12:32 pm
Benny wrote:If the holes are actually cast into the rotor, they are fine, but if they are drilled after the disc is cast, then they can start cracks as the drilling stresses the metal.
came with the car. not my choice. i was looking into the Wilwood big brake kit :mrgreen:
kitkat, boags, i dont have the car back yet. when it gets back you will definately get to see it, and have a ride in it. and have a beer while looking at it :lol:
DOYLMX5
Postby DOYLMX5 » Thu Mar 22, 2007 11:41 pm
dont go the wilwood
I have been told that all they do is upgrade the front brakes.
for the rears they just have a spacer for the calipers and put in a bigger rotor. so you get all this extra braking power at the front but pretty much exactly the same on the back.
If you are willing to wait a fewish weeks a member from the advan group (we call the place WHEELSPIN) has just made their own kit comprising of mainly RX-7 brakes which are as a matter of fact... bigger than the wilwood kits including bigger calipers and rotors for the back.
The front has 12\" rotors and 4 piston calipers while the real has the same rotor i think but big single piston calipers.
PM the guy, MX52NV
the kit is his and it is still prototype at the moment but he is hoping to put it into production really really soon.
Big Up for Wheelspin!
irwin83r
Postby irwin83r » Fri Mar 23, 2007 12:44 am
DOYLMX5 wrote:dont go the wilwood
The front has 12" rotors and 4 piston calipers while the real has the same rotor i think but big single piston calipers.
PM the guy, MX52NV
wouldnt they be heavy as buggery though??
i thought that was half the reason behind good brake kits... like willow and APR the fact that their calipers wiegh about 1/4 that of a standard caliper :|
i think the UK store has some good APR brake kits worth looking at... havent got a link :? but i do remember them looking the goods.. and should be lighter/better than a factory rx7 brake kit.
lil_mike
Postby lil_mike » Fri Mar 23, 2007 8:20 am
i'm not actually going to get new brakes yet guys. the brakes are fine on this car and really grip well. my only concern was the drilled rotors.
PS: kitkat, boags, check up on the build thread frequently, i'll post up in there when i know when the car is coming out.
rhysk
Vehicle: NB8A - Supercharged
Postby rhysk » Fri Mar 23, 2007 8:51 am
But it is about heat and not speed. A 380 mm Porsche rotor can dissipate enough heat to stop from 250 repeatedly. Secondly, the Porsche rotors are much better in quality than $150 DBAs. I saw new DBA cross drilled rotors crack on an S14 after 10 laps at QR, that was with stock power. The NA6 has tiny rotors, so while lil_mike should be OK on the street, I wouldn't go on a track.
supercharged NB (in Brisbane) - qr 1:01:75 (s), 1:05.90 (c)
jaguar xjr supercharged v8
lil_mike
Postby lil_mike » Fri Mar 23, 2007 9:36 am
well, i had a look for replacement brake kits and came across these :mrgreen: they're brembo's
Clicky Clicky
yes i am aware the pictures have drilled ones but they come in whatever you choose for them. Drilled or slotted.
Users browsing this forum: No registered users and 209 guests
