zoomzoom wrote:They are in NSW Boags
Yes, the QLD situation is a little different, although, it must be said that it is a squillion times easier to get a mod plate here.
I'd still like to see rule book on this one, I'd say that cams and ecu would need an engineer's cert.
Crocaine: It is a much harder task than you are thinking. It costs a lot of money, and then when completed, you are behind factory manual cars because of the differences in build.
Find a car that has a good (well documented) history and save yourself the heartache and $$$. It just isn't worth it, there are sooooo many factory manual cars to choose from.
Boags
