Turbo day III - the boost wants loose.....so close, so close
Sean
Postby Sean » Mon Mar 19, 2007 12:48 pm
All I can say is 8)
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Tue Mar 20, 2007 12:08 am
Sooooo - not to be outdone by Goags - I mean Boags...
Here is my heatshield. It's not as bling as bling can be, but it's a bugger to make these things from scratch. I don't know how some of the guys get their DIY airboxes/heatshields looking so damn good.....
I'm hoping it does what's needed.
Boags
Postby Boags » Tue Mar 20, 2007 12:26 am
8) :mrgreen:
Nothing wrong with a bit of friendly rivalry... We'll have to dyno on the same day too! :lol:
Garry
Postby Garry » Tue Mar 20, 2007 9:58 am
Do it in cardboard first UA, have a few goes till you get it right, then do the final product.
The one Russell did at short notice for the Moneypit wasn't pretty, but it did the job.
Uncle Arthur
Postby Uncle Arthur » Tue Mar 20, 2007 11:14 am
Garry wrote:Do it in cardboard first UA, have a few goes till you get it right, then do the final product.
Bit late for that now, seeing as I did it last night.....
It's hard to see from the pics, but it wraps around the whole side of the turbo between the turbine and the airfilter, and around the dumppipe, between it and everything else - leaves about 10mm clear space on both sides of the shield.....
It's a good material to work with, but the shaping was tricky..... as the cuts on my hands are proof of.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Tue Mar 20, 2007 11:38 am
Sean
Postby Sean » Tue Mar 20, 2007 5:59 pm
A great idea, but they are often troublesome with the actuator on internally gated turbos.
Sheck
Postby Sheck » Tue Mar 20, 2007 6:31 pm
Looks like it'll do the job for radiated heat but i'd prolly get a box around that filter too and get the air feed from your old cowl induction, you'll be suprised at how hot it get under the bonnet there! and at how much of a differenc the boxing in of the pod does.
Keep up the good work!!!
Dave
sabretooth
Postby sabretooth » Wed Mar 21, 2007 12:18 pm
What size is that compressor outlet?
Uncle Arthur
Postby Uncle Arthur » Wed Mar 21, 2007 12:21 pm
sabretooth wrote:What size is that compressor outlet?
38mm ID or thereabouts
Cal
Postby Cal » Wed Mar 21, 2007 3:40 pm
That's a bit more together than when I last saw it. :D I would not be leaving that filter there at all. Can't you put it right out the front or something?
Cal.
lowmiata
Postby lowmiata » Wed Mar 21, 2007 11:11 pm
Cal wrote:That's a bit more together than when I last saw it. :D I would not be leaving that filter there at all. Can't you put it right out the front or something?
Cal.
your sort of limited to the legnth of the airflow meter wiring
you could legnthen it but where ever you re route it to you still need to have the big dirty AFM!
i say ditch the f'er! so much more creative possiblities!
EVI15 1998 to 2008
Cal
Postby Cal » Thu Mar 22, 2007 10:02 am
Oh yeah forgot that bit. Got a map sensor on both my cars.
Cal.
lowmiata
Postby lowmiata » Thu Mar 22, 2007 11:12 am
Cal wrote:Oh yeah forgot that bit. Got a map sensor on both my cars.
Cal.
me too!
got to love no airflow meter!
EVI15 1998 to 2008
