Turbo day III - the boost wants loose.....so close, so close
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Sat Mar 17, 2007 10:12 pm
LM didn't have anything to do with Boags' funny engine bay noises, but he is responsible for this :D......
And this...
He was not responsible (directly) for this - this is what happens when aftermarket 'bolt on' parts (like the NPower dump pipe) don't actially bolt up and need extensive modification.
First it needed to be cut just to get it to be able to bolt up to the turbo. Don't aske me how much trouble we had trying to get the bottom stud connected.
Next, I have to find a way to shift the water return pipe because the O2 sensor position is right in the way (and I'm not pulling the dumppipe back off after it took an hour to fit up.
That said - we got it to start this afternoon, and the oil is happily being pumped to the turbo, and it still runs..... :D
Boags
Postby Boags » Sat Mar 17, 2007 10:17 pm
Looking good UA... Yep, it is a joy to hear it start for the first time, isn't it?
Boags 8)
Garry
Postby Garry » Sat Mar 17, 2007 11:03 pm
mmmmmmmmm booooost 8) :mrgreen:
StanTheMan
Postby StanTheMan » Sun Mar 18, 2007 8:26 am
All the hard work is comming together....did you & boagsy do a group buy on Turbos?
ROFLMHO . :lol: :lol: :lol:
JSE
Postby JSE » Sun Mar 18, 2007 10:59 am
looking good UA. so much hardwork you're putting in I hope it turns out a ripper!
Fatty
Postby Fatty » Sun Mar 18, 2007 11:26 am
StanTheMan wrote:All the hard work is comming together....did you & boagsy do a group buy on Turbos?
that's not as funny as you might think stm 8)
Fatty
Postby Fatty » Sun Mar 18, 2007 11:36 am
oh, great set up by the way UA. looking very nice.
StanTheMan
Postby StanTheMan » Sun Mar 18, 2007 11:56 am
Even more hillarious if its true......especially if you were involved in this group buy.
but.....apart from the Turbo Group Buy.......Great seeing all the work comming together Uncle Urthur. Job well done.
jules
Guitar Hero
Postby jules » Sun Mar 18, 2007 12:23 pm
This has been in planning stage for longer than I can remember. Like Mad Max \"A piece from here, and a piece from there\", and now look at the result.
This is so exciting to watch. I can't wait for a drive :mrgreen: , then again, perhaps I shouldn't go there.
LM, you are the dude!
Jules
JSE
Postby JSE » Sun Mar 18, 2007 12:47 pm
I think its great. Not many people opt for the DIY turbo conversion these days with so many readily available kits. :lol: @ Stan and Fatty.
I like the air filter setup, good for a little bit more cold air still sucking from the cowl inside of covering it up again with the washer bottle.
Uncle Arthur
Postby Uncle Arthur » Sun Mar 18, 2007 1:13 pm
jules wrote:This is so exciting to watch. I can't wait for a drive :mrgreen:
Jules
I'll have my people talk to your people :D
sabretooth
Postby sabretooth » Sun Mar 18, 2007 7:09 pm
Ryan's a master with pipes, isn't he? :)
Are you ditching your aircon?
And that looks like a bugger of a place to put the oil return!
Uncle Arthur
Postby Uncle Arthur » Sun Mar 18, 2007 10:04 pm
sabretooth wrote:Ryan's a master with pipes, isn't he? :)
Yes he is :D
No I'm not - getting it recharged in fact.
It wasn't as bad as it looked at first - when we found out how easy it was to modify the bracket it turned out that fitting was a cinch - I hooked the oil drain line this afternoon and turned it over - if some one can host it for me I'll put up the little video that Jen took of the 'official turning of the key'.
Sheck
Postby Sheck » Mon Mar 19, 2007 9:46 am
What are you gonna do to protect the water line and air filter from all that heat?
One track day and it'll be melted/on fire (i know about that fire thing first hand :lol: )
Otherwise it's all looking very neat indeed!! Good work mate!
Dave
Uncle Arthur
Postby Uncle Arthur » Mon Mar 19, 2007 10:40 am
I will be constructing a heat shield.
Just got to work out how, and get the material.
