Headlight Covers NA6
DOYLMX5
Postby DOYLMX5 » Sat Mar 10, 2007 12:26 pm
Hi there all!
I have seen on numerous occasions where someone has posted pics of thier new na6 or 8 and someone has come long and said \"get under those headlight covers and lift em up a bit\"
I have had an extensive look at them and can't figure it out.
The mechanic I go to doesn't know what those people are talking about.
I want help with this please.
Mine are so far out of whack you could almost fit a 5cent piece through one of the gaps (not the skinny side).
Any links to other threads like this or just someone saying how it is done would be greatly appreciated.
Thanks a lot everyone.
Jason
Philip Lee
Postby Philip Lee » Sat Mar 10, 2007 1:01 pm
step1: pop the headlights up;
2: use a phillips screw driver and unscrew the screws on the black plastic covers around the headlights. there are 8 in total (2 screws on the 4 sides);
3: you'll see there are another 8 screws in total (2 on each side) that the cover is held;
4: undo them, adjust and redo them;
5: put the black covers back in the reverse order of above.
6: done and have a beer 8)
STV
Postby STV » Sat Mar 10, 2007 1:41 pm
or, just pop the bonnet and gently hold the back side of the headlight assy,
gently liflt until it is the same height as the front quarter panel
close the bonnet to ensure that the amount of lift is the same as your bonnet
If yes, all good, if no, repaeat above steps til you get it right!
Where is 'Home Sweet Home'?
DOYLMX5
Postby DOYLMX5 » Sat Mar 10, 2007 2:47 pm
Thanks guys,
step 6 sounds good :P
chrislevingston
Postby chrislevingston » Sat Mar 10, 2007 4:00 pm
What STV said.
Dead easy :D
Chris
1990 "TOY MX5" - Red, of course!
Kings, Konis, LSD, Genie system, grille, Voodoo knob, braces, 14 degrees ATDC, woodgrain dash,style bars and lots of work making the rubber bands go around faster.
StanTheMan
Postby StanTheMan » Sat Mar 10, 2007 4:27 pm
sttep 6.....mmmmm but i prefer Bourbone or Scotch....mmmmm....is it Beer o'clock yet ?
almost..... :mrgreen: :mrgreen: :mrgreen:
Fatty
Postby Fatty » Sat Mar 10, 2007 4:32 pm
yeah just grab the thing and yank it with your hands. push and pull until you get it right. easy!
GS
Postby GS » Mon Mar 12, 2007 1:57 pm
Philip Lee wrote:step1: pop the headlights up;
Hi guys
Re: point 4
If the screws are painted over what is the best way to shift them without stripping the phillips head?? Any trade secrets?? I want to remove my cover but not make a mess of the screws??
1989 NA6
lil_mike
Postby lil_mike » Mon Mar 12, 2007 2:08 pm
power tools :mrgreen: i recommend Snap-on :lol:
seriously now, hmmm, not sure.
Philip Lee
Postby Philip Lee » Mon Mar 12, 2007 3:01 pm
GS wrote:Re: point 4
i had the same problem with mine and that's y i didn't suggest pulling cos no amount of pulling worked for me and i dun wanna damage anything.
unfortunately i had to kill those screws to do mine.
Fatty
Postby Fatty » Mon Mar 12, 2007 3:05 pm
paint stripper ? :shock: and just be very careful when you apply it ? ?
Philip Lee
Postby Philip Lee » Mon Mar 12, 2007 3:13 pm
Fatty wrote:paint stripper ? :shock: and just be very careful when you apply it ? ?
i thought about it but it's too much a risk and there is no gurantee that it'll work.
it seems those 18 yo screws on mine are a bit too soft.
GS
Postby GS » Mon Mar 12, 2007 5:27 pm
Thanks guys. So in the end you just drilled them out Phillip??
1989 NA6
Philip Lee
Postby Philip Lee » Mon Mar 12, 2007 5:31 pm
GS wrote:Thanks guys. So in the end you just drilled them out Phillip??
I drilled 2 of them out until my mate turned up with those screw heads that are used to undo tough or rounded screws.
lam.666
Postby lam.666 » Mon Apr 16, 2007 7:13 pm
does anyone know with the na6 headlights,
are they supposed to pop up, on the first click, or only on the 2nd click?
Users browsing this forum: No registered users and 30 guests
