HELP!!! NA Pop-up headlight NOT poping up!
- Mr Starlet
Hey All
What does it mean when my pop-up headlight won't pop up unless I use the button below the hazard?
Any pointers would be much appreciated.
Minh
Minh
- Mr Starlet
kitkat wrote:fuse?
Do the lights turn on?
Lights goes on but not poping up, is there a dedicated fuse for poping the light up?
- kitkat
Click the link to view the wiring diagram for the lights.
Hope you can read electrical diagrams
http://test.miata.net.au/headlights.jpg
- kitkat
can also have a look at...
http://test.miata.net.au/headlights1.jpg
Edit: Mr Starlet... have i geven you a copy of the workshop manual yet? There is a complete trouble shooting process in it. Im going through it now ill post if i find anything.
- Mr Starlet
kitkat wrote:can also have a look at...
Yep going through the manual now...it's pain looking through that PDF
- JBT
Mr Starlet wrote:Yep going through the manual now...it's pain looking through that PDF
Save your energy and find the retractable headlight relay. Hint: it's not in the engine bay where they say it is for the US market cars.
- Mr Starlet
JBT wrote:Mr Starlet wrote:Yep going through the manual now...it's pain looking through that PDF
So where would I find this relay? under the driverside where close the fuse box?
- JBT
- Russellb
- RIP Nov 2014
Check that the Tail lights work. The tail light fuse operates the pop up Relay. the button on the dash bypasses the relay ( well on the NA 6 it does)
The hidden relay is under the dash on the drivers side, near the steering column, remove the plastic panel under the column to gain access.
Hope this helps
Hope this helps
My ClubmanRebuild
MX5 SE Rally car is HERE
- JBT
My understanding is that power for the operating side of the retractor relay comes through the \"head\" fuse via the headlight relay. The Motor power then come via the centre console override button.
Check this diagram
Check this diagram
- Russellb
- RIP Nov 2014
That is not the same wiring diagram I have. I have the Mazda Australia
book . for both the 89 NA and the 95 NA, there is a differance for the 2 models.
will take a Pic of the pages and post them up tomorrow
My ClubmanRebuild
