Car wont start :(
Andrew
Postby Andrew » Thu Mar 08, 2007 11:24 am
Everytime i shorted the pump the relay switched.
I tested the supply this morning and there is power getting to the pump connector on the top of the fuel tank.
KIJIMA
Postby KIJIMA » Thu Mar 08, 2007 12:09 pm
I was suprized how cheap a non-genuine fuel pump was $138.33 considering it was of a higher flow rate than the gen pump. (probably better suited to turbo/SC applications I guess.
Probably easier to go for the gen mazda part in the long run, plus you have peace of mind.
Money can't buy Talent, but it can buy Horsepower and sometimes that's enough
Fatty
Postby Fatty » Thu Mar 08, 2007 12:15 pm
kijimi, what pump is that? and where did you get it for that price?
Andrew
Postby Andrew » Thu Mar 08, 2007 12:16 pm
KIJIMA wrote:Probably easier to go for the gen mazda part in the long run, plus you have peace of mind.
Yep thats what i'm after.
KIJIMA
Postby KIJIMA » Thu Mar 08, 2007 12:45 pm
Fatty wrote:kijimi, what pump is that? and where did you get it for that price?
Didnt ask what brand, and from work.
Andrew
Postby Andrew » Thu Mar 08, 2007 12:54 pm
KIJIMA wrote:from work.
Dodgy Dan's Discount Fuel Pumps Pty Ltd :mrgreen:
KIJIMA
Postby KIJIMA » Thu Mar 08, 2007 1:39 pm
Yup, Just like for the sign out the front with the car that has its mirrors folded in!
Bevan
Postby Bevan » Thu Mar 08, 2007 1:50 pm
What does the pump look like? :?
KIJIMA
Postby KIJIMA » Fri Mar 09, 2007 10:46 am
Bevan wrote:What does the pump look like? :?
Like a fuel pump... :roll: :P
Andrew
Postby Andrew » Fri Mar 09, 2007 11:45 am
I'll take some pics just for you Bevan whin i replace mine :mrgreen:
StanTheMan
Postby StanTheMan » Fri Mar 09, 2007 2:34 pm
ROFLMHO :lol: :lol: :lol:
Broockvale Mazda
1 Fuel pump $980.95 inc GST
Now thats entertainment
Andrew
Postby Andrew » Wed Mar 14, 2007 10:06 am
Ok, here goes with a DIY fuel pump replacement -
First a warning or two, you will be dealing with fuel and electricty, so NO smoking and disconnect your battery and ground yourself before starting this procedure.
First to gain access to the fuel pump by rolling up the carpet and removing the tin panel held on with six bolts to gain access to the fuel tank -
The fuel pump is located under this panel -
Remove the electrical connection and the fuel lines going to and from the fuel pump, then undo the screws and carefully remove the pump from the car. The filter on the bottom of the pump along with the fuel lines will hold petrol in them so be careful no to spill any petrol in the car.
The pic shows the complete fuel pump assembly -
...and the fuel pump with filter attached -
to be continued once i collect my new fuel pump :)
bigdog
King of the kennel
Postby bigdog » Wed Mar 14, 2007 10:16 am
Nice pink interior Drew :oops:
Andrew
Postby Andrew » Wed Mar 14, 2007 10:23 am
bigdog wrote:Nice pink interior Drew :oops:
Its not my fault Mazda dont paint all the car :cry: :P
fredbareoz
Postby fredbareoz » Wed Mar 14, 2007 12:16 pm
show us ya pink bits Drew!!! :mrgreen:
Black SP Turbo. Tiens and Guru LSD.
