My drivers door has dropped a mm or so, how to adjust the hinges so it closes easily?
The Enthusiasts's Workshop Manual doesn't help much - just says adjust the hinge bolts - I can see how to raise/lower the whole door, but not just raise the outer edge.
It feels like the top hinge pin has worn, if the door is rocked up and down there is some movement.
How to adjust drivers door
- Gazbo
- bigdog
- King of the kennel
- lowmiata
- Gazbo
manga_blue wrote:There's a squarish rubber block on the door frame below the latch, black thing the size of a bar of soap. Genuine replacement cost is $12.50. It's there to help locate the door and stop it rattling. Check it out - some are very worn or have chunks torn off.
My block is in good condition, the door rides up onto to it a little when the door shuts.
