tiens ss + edfc
ducktape69
Postby ducktape69 » Sat Feb 24, 2007 2:47 pm
any DECENT suspension place can order them and install for u....
id recommend STRAIGHT TALK SUSPENSION in blacktown...
i got my KYB/kings from there with alignment...i get my alignments done there every 6 months. the owner(lou) knows what he is doing especially with mx5's.
BLECK 2002 Mazda MX5 NB8B. Custom Heatshielded CAI . KYB AGX's + King Springs. 17\" Bleck Rims. Custom BASSSS Install.
Brad
Postby Brad » Sun Feb 25, 2007 10:33 pm
The SS also has adjustable height, but by doing so you are also reducing the travel in the suspension, the Flex will allow you to adjust the spring pre-load and ride height independently. The SS however are the only MOT legal coil-overs that I know of, and also have a stiffer spring than a standard flex. If you are not wanting to go too low (which you shouldn't anyway for handling sake) the SS will be perfect.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Mon Feb 26, 2007 10:14 am
i stand by getting ss's as the best mod i could have done for the money. edfc is not needed. the rear's are a bit of a pain to get to but its all part of the challange. That said i do plan to get edfc eventually so if you have the dough to spare its probably worth getting them done at the same time.
Babalouie
godfather of saké
Postby Babalouie » Mon Feb 26, 2007 3:58 pm
16bit wrote:i stand by getting ss's as the best mod i could have done for the money. edfc is not needed. the rear's are a bit of a pain to get to but its all part of the challange. That said i do plan to get edfc eventually so if you have the dough to spare its probably worth getting them done at the same time.
It is good fun to play with though. You can fiddle with the EDFC while you're on the track and you can really feel the change in balance as you fiddle with it :D
Although it's definitely a case of : 32 clicks, 256 possible combinations, 255 possible ways of buggering up the handling :D :D
CT
Postby CT » Tue Feb 27, 2007 8:12 am
Brad wrote:The SS also has adjustable height, but by doing so you are also reducing the travel in the suspension, the Flex will allow you to adjust the spring pre-load and ride height independently. The SS however are the only MOT legal coil-overs that I know of, and also have a stiffer spring than a standard flex. If you are not wanting to go too low (which you shouldn't anyway for handling sake) the SS will be perfect.
SS are about 100lbs softer than Flex in the spring rates - SS=283lb fronts, Flex=392lb fronts.
Brad
Postby Brad » Tue Feb 27, 2007 10:09 am
This page says that the SS's are 392/336, same as the Flex.
http://www.tein.com/mazda.html
CT
Postby CT » Tue Feb 27, 2007 2:03 pm
Nice catch Brad. :D They have must have changed them. My SS's are 283/200 or therabouts and are late 2005 models. I know another set which was purchased in early 06 which are also 283s as they have now put flex springs in them as they were too soft for a race car. The site also says EDFC not compatible.
Brad
Postby Brad » Tue Feb 27, 2007 2:15 pm
We need to keep in mind however that Fulcrum customised the SS when they came out here, so the AU spec could be different. My SS's are EDFC compliant.
There are heaps of springs available for the SS mind you, take a look here.
http://www.tein.co.jp/e/price_list/racing_spring.html
Not sure what spec the MX5 springs are though. 16,000yen per set of 2, thats $167AUD
Postby Okibi » Mon Mar 05, 2007 2:44 pm
and you got $500 off ... if Bloodnut pays up. :mrgreen:
RaYmO
Postby RaYmO » Mon Mar 05, 2007 3:53 pm
Okibi wrote:and you got $500 off ... if Bloodnut pays up. :mrgreen:
Just remember, don't accept Sherman Cash... :lol: :lol:
