bigdog wrote:Could also be embarrassment - maybe Patchy is tired of running around half naked and is hiding till you come up with a nice red coat
could well be bigdog
OK. No action from the pump when ignition gets turned on. No hissing or humming
lowmiata I'm not entirely sure what you ment with
" your hand on the rocker under the door and feel the car hum when the pump runs "
turned it over a few times......spark plug is as dry as The Simpson Desert.
got Spark
no fuel
try to conserve the battery now.
fuel filter probably needs to be changed anyway.......hasn't been changed in ages.
Whats the most logoical way to check from here.
