Retractable Power Antenna
- Wuey
Personally I wouldn't bother with a powered antenna based on my past experience with them. With a bigger diameter they attract dirt faster. OK, you can clean and lubricate it regularly but the grits will get into the gaps causing problems. Sooner than later, it will get to a stage when it will not extend or retract fully. More headaches for what it's worth. Besides, I don't mind the RC look of the stock antenna.
- JSE
- Old EmmGee
- SuperMazdaKart
- Ajay
GP wrote:My import didn't!
That's funny, My owners manual shows it being a genuine Item
mines a 1990 import,
definatelly has the RC look...
if someone gets a better one on the way, put me down for a group buy =)
- FUN-29T
I'm using one of these retractable antennas..http://www.aerpro.com.au/p.php?pcode=AP64&cat_no=13 it required a bit of cutting of the antenna's plastic sleeve at the bottom which cant be seen anyway. They should cost around $10.. you can also find this in another brand in Kmart or BigW in a different brand and i think they're even cheaper than the Aerpro brand..
Users browsing this forum: No registered users and 186 guests
