Dangers of 7200rpm+ ?
Ted
Postby Ted » Tue Feb 20, 2007 8:04 pm
You'd want to be pretty brave to keep running it to 8000rpm. I ran my old 1.6L to 7400rpm mostly, did have it set at 7600rpm for a while but trimmed it back for the longer events. I did have a very light flywheel too. Car made bugger all more power above 7250 anyway with the std cams, I simply had it so that I could hold gears a bit longer in certain places. Fixed it by going to slightly taller tyres.
Motorsport is a disease, where the only cure is poverty!
The ego writes cheques that skill can't cash - DJ
CT
Postby CT » Wed Feb 21, 2007 9:18 am
rjr666 wrote:
CT wrote:At 8000rpm, you need solid lifters and better valve springs. 8)
CT can you recommend some solid lifters and valve springs? And where to get them from?
So gtr springs fit eyyy??? :P
Mazda solids from an NB are a good place to start. Then you need to use a solid lifter camshaft as well. Any good valve springs will do, I use the FM ones with the titanium retainers. A lightened bottom end and better rod and rod bolts will help maintain reliability.
Unless you put in a cam that is suitable for making power up there, it's generally a waste of time and money. That said, my old engine made power up to 8300rpm before it tailed off. 8)
RaYmO
Postby RaYmO » Wed Feb 21, 2007 9:32 am
Im hesitant to rev my NA6 beyond 6k cos everything starts to rattle!
Postby fastfreddygassit » Wed Feb 21, 2007 3:11 pm
lil_mike wrote:probably one of the best mods for high rpm is adjustable cams. get a pair of those and you'll be making more power up there.
what, like vtec....YO!
:mrgreen:
