Rolling Noise…need new tyres or wheel bearing?
Chris P
Postby Chris P » Mon Feb 05, 2007 12:01 pm
Hi guys,
I have a “woo…woo…woo…woo” rolling noise coming into the cabin. There is no hissing or metal grinding. Others have suggested that it could be a wheel bearing?
How can you tell if a wheel bearing has gone? Is replacing a wheel bearing expensive?
Hot Rodders
Postby Hot Rodders » Mon Feb 05, 2007 2:02 pm
Sounds typical wheel bearing. Ca't remember how much. Around $100
Most likely cheaper if you do it yourself. Suggest check others at the same time as they can tend to go around the same time as I found out.
Evo, Its not a Dirty Word! Good As Gold.
President Bendigo Gliding Club
www.bendigogliding.org.au
bark
Vehicle: NA6 - Turbo
Postby bark » Wed Feb 14, 2007 5:58 pm
I have the same problem on the left, its a wheel bearing!
irwin83r
Postby irwin83r » Wed Feb 14, 2007 7:35 pm
dont go straight to mazda for a bearing. some times other places like SKF and FAG can be loads cheaper and the quality dosnt vary all that much. SKF are more then trustable.
as far as checking goes you can do a lift check and see how much clearance is in the bearing and compare that to specified.... but thats going a little far... id just jack up the suspect corner and see if i could wobble the wheel and feel how rooted or if it was rooted at all.
JBT
Postby JBT » Wed Feb 14, 2007 11:13 pm
These cars (NA in particular) seem to transmit a lot of rear end and road noise into the cabin when the roof is up. I've had at least two \"mechanics\" claim that the rear wheel bearings are stuffed - but they aren't.
One way to tell if it's a bearing is get on a smooth wide open road and weave from side to side. If the noise gets worse or stops when the wheel on one side is loaded/unloaded then that would indicate a bearing problem.
Chris P
Postby Chris P » Mon Feb 19, 2007 5:07 pm
Just got new tyres - phew - its not a bearing - the old tyres were absolute crap! :D
Users browsing this forum: No registered users and 188 guests
