Broken Diff
Grumpy
Broken Diff
Postby Grumpy » Sat Feb 17, 2007 9:11 pm
Photo of broken diff housing from 89 MX5.
Is this a common problem ??
Sadly MX5 less for a while.
Rebuilding an 89 Honda CRX
Babalouie
godfather of saké
Postby Babalouie » Sat Feb 17, 2007 9:17 pm
How the hell did you break it THERE? :shock:
Grumpy
Postby Grumpy » Sat Feb 17, 2007 9:38 pm
Don't know Babaloui, it was like that when I bought the car. (see $3900 mx5 in for sale section) Th r/h stub axle has a huge amount of wear on the end of the spline, and the inside of the diff where the stub fits is oval !! Must have made some horrible noises. Can't see how this would account for the break though. :?:
Andrew
Postby Andrew » Sat Feb 17, 2007 9:48 pm
a forklift perhaps :?:
Mr_Q
Postby Mr_Q » Sat Feb 17, 2007 10:22 pm
I've seen a couple that have broken there from accidents. You can get it welded back together if the rest of the diff is ok.
Mister Q
Had: Red 2004 SE, Red 1993 NA8 Clubman, Green 1991 NA6 LE
Garry
Postby Garry » Sat Feb 17, 2007 10:28 pm
It's suposed to snap off in the event of a collision at the rear as a safety feature. But I thought it was supposed to break a bit further along the arms, not right at the diff housing like that one.
Craig
Re: Broken Diff
Postby Craig » Sun Feb 18, 2007 1:10 am
Grumpy wrote:Is this a common problem ??
Only if you give Stefan the keys! :lol: :P
rjr666
Postby rjr666 » Sun Feb 18, 2007 4:19 am
as gary said, in the event of a rear end accident it snaps. as your car was bought from the auctions damaged in the rear end this is the most likely result.
I have seen one break that far up on the diff housing before. I through the housing out and just got a new one.
I need a sponsor
StanTheMan
Re: Broken Diff
Postby StanTheMan » Sun Feb 18, 2007 11:07 am
*Slaps Craig*
it is common for 1.6 diffs to break......but not where this is brocken.
the diff has a weak point so it snaps in heavie rear end collisions.....just like garry said......kind of a safety feature
this is a more common place for it to snap. something snapped internally & brocke the casing from the inside
you should be able to pick another one for around $500......or even cheaper.
Craig
Re: Broken Diff
Postby Craig » Sun Feb 18, 2007 12:58 pm
StanTheMan wrote:
Craig wrote:Only if you give Stefan the keys! :lol: :P
*Slaps Craig*
What no tickle? :lol: :P
ampz
Vehicle: NA6 - Turbo
Re: Broken Diff
Postby ampz » Sun Feb 18, 2007 3:17 pm
*Slaps Craig*
Now he tells me :shock: :lol: :P
Huh?
Craig
Re: Broken Diff
Postby Craig » Sun Feb 18, 2007 9:15 pm
ampz wrote:Now he tells me :shock: :lol: :P
OI! :P :mrgreen:
Grumpy
Postby Grumpy » Sun Feb 18, 2007 9:28 pm
Comments make facinating reading, thanks guys.
Anyway, have another diff ready to go in, an LSD this time.
StanTheMan
Postby StanTheMan » Sun Feb 18, 2007 9:33 pm
that would be the one sitting next to it. :lol:
Sean
Postby Sean » Sun Feb 18, 2007 10:20 pm
The SR20DET powered MX5 in teh states broke in teh exact same place - No accident, apparently due to old age and excessive power...
