Whats a good base for tuning cams?
Hey guys, my cam gears should be comming in this arvo so the will be going in as soon as i get my hands on them.
Has anyone got any tips on tuning them? I was told by a trusted mechanic that retarding the exhaust cam is the way to go - said the car will haul arse with that.
I modded a spare cam cover yesterday, so i'm all set for the install. Just need some tips, so any help is greatly appreciated!
Dave
Dave
- godfather of saké
- godfather of saké
- godfather of saké
Sheck wrote:heheh cool thanks, well just out of interest how did you tune your n/a cams?
Cheers!
Dave
I used the timing which Tomei recommended....which was the stock timing!
- Astroboysoup
tried asking some of the US guys???
alot of them have turbs and cams
AustCars.net - It's like Facebook but for cars!
- Sean
Best thing is to get it on a dyno and start with zero, retard a little, advance a little and eventually you will find the sweet spot.
I've seen cams produce peak torque 16 degrees away from where they produce peak power, so be sure you know what you want before turning too much to the advice of others.
Yea thanks Sean, I really need to get my beast onto a dyno soon. Actually put some timing into her so i can pull out some power.
I did some road tuning again today, all i did was retard the exhaust cam by 5deg (2 and a half notches) and the power band has moved back to about 4.5k rpm (instead of the previous 5k rpm). I'm just gonna leave it at that untill i can get to a dyno and tune it properly. Oh and the AFR remained the same.
Oh and the boost spike is a bit worse than before but still not that bad i guess.
Dave
PS anyone know a good EManage tuner on the south side of brissy that will let me help him out while tuning?
Dave
Sheck wrote:PS anyone know a good EManage tuner on the south side of brissy that will let me help him out while tuning?
Simon at McGregor Mechanical tunes my race car but I'm not sure if he can do EManage?
Neil
SP Race Car
RS Clio
ML 300
RS Clio
ML 300
just gave the car a bit of stick on the way home from the archefield drifts and it feels heaps better than before!!! good old cold air helped it alot!! great midrange push (the boost spike helps with this) then continues to pull well up to the redline (with the lower boost).
Only problem is the boost spikes up to about 14-15psi then comes back down to 12. Used to be a smaller spike. I'll have to chack on all the auctuator lines over the weekend make sure there are no additional leaks (got man boost contorller)
Dave
Dave
- john!
