Moving number plate
robbiew
Moving number plate
Postby robbiew » Sun Feb 11, 2007 7:26 pm
Question:
I have a slim line front number plate mounted on a bracket that has the plate upwards on nose cone. Can you mount plate in \"gap\" on front without upsetting the cooling?? I have seen some photos of this done, but wonder about air flow to radiator.
Robbiew.
Fatty
Postby Fatty » Sun Feb 11, 2007 7:32 pm
some people seem to get away with it, but others report problems with cooling. not worth the risk imo, especially if you like a bit of spirited driving .
robbiew
Moving number plate
Postby robbiew » Sun Feb 11, 2007 7:52 pm
Thanks....unfortunately LOVE spirited driving...any other kind in a 5?? Seriously, does get the odd workout so maybe leave plate where it is....
Thanks for the prompt reply
robbiew
Juffa
Postby Juffa » Sun Feb 11, 2007 8:41 pm
There are a number of other options. Try a search and you might see something else that will suit.
J
Alex
Postby Alex » Mon Feb 12, 2007 3:45 am
you could also try the \"jap\" mounting method where a braket is placed on the passenger side front toe/shipping loop, so number plate is mounted off-centre and not in the way of the front grill in any way
Mr_Q
Postby Mr_Q » Mon Feb 12, 2007 11:21 am
Cable tie it in the mouth so it blows up out of the way when you're moving. :)
Mister Q
Had: Red 2004 SE, Red 1993 NA8 Clubman, Green 1991 NA6 LE
pinkie
Postby pinkie » Mon Feb 12, 2007 1:26 pm
That will make it a moving number plate then? :)
Fatty
Postby Fatty » Mon Feb 12, 2007 1:57 pm
pinkie wrote:That will make it a moving number plate then? :)
could also be called a "moving violation" :D
Adam_NAclubman
Postby Adam_NAclubman » Mon Feb 12, 2007 2:38 pm
No cooling proiblems with mine sittingin the gap
broady
Postby broady » Mon Feb 12, 2007 3:28 pm
SM wrote:you could also try the "jap" mounting method where a braket is placed on the passenger side front toe/shipping loop, so number plate is mounted off-centre and not in the way of the front grill in any way
Is there a write-up on such mounting methods?
jules
Guitar Hero
Postby jules » Mon Feb 12, 2007 3:42 pm
Try this http://www.onthenet.com.au/~malibu91/julesplate.htm
I'm happy with the result. It's legal and the car won't overheat.
Jules
robbiew
moving number plate
Postby robbiew » Mon Feb 12, 2007 9:00 pm
Thanks to all who replied....I will certainly have a go at the mods suggested....and post results if I do a reasonable jobbie !!!
robbiew
zoomzoom
Vehicle: NA6 - Turbo
Postby zoomzoom » Mon Feb 12, 2007 10:37 pm
I made two small brackets for mine which bolt onto the very underneath of the nose cone where you would bolt on a front lip spoiler. There are two bolts there almost the right distance apart. I tried mounting it offset to one side but didn't like the look so I put t there, is out of the way of most of the air flow and looks a little like the shark mouth is eating it :D
Sry I dont have any pics I dont have the car right now, its at the shop getting the sills done.
Tim
Sean
Postby Sean » Tue Feb 13, 2007 12:53 am
Take it off...
Take it all off...
Go to the local RTA office and tell them someone stole it, and ak for it to be remade. (cost is approx $30).
They will give you a receipt stating the plate is being remade. Keep the receipt in the glove box - bit conveniently spill a little sun block over the date so it fades or runs into obscurity.
HEY PRESTO you have a get out of gaol free card :mrgreen:
$30 and some sunblock is cheap compared to actually doing some physical work and buying materials :shock:
RG.net
Postby RG.net » Wed Feb 14, 2007 7:44 pm
sean your one lost kid !
Users browsing this forum: Bing [Bot] and 1 guest
