Postby The Pupat » Tue Feb 13, 2007 4:56 pm
Sean wrote:The Pupat wrote:Sean wrote:manga_blue wrote:Bosch Australia make individual coils that are popular all over the world for EVOs and WRXs. You use one per plug and place then as close as possible to the plug, giving a really short HT lead. About $50 each. Can't remember the type - just check the WRX forums searching for Bosch and coilpack.
I've investigated the bosch coils, problem is they like to have a hell of a lot of dwell and out little wastespark system is incapable of supplying enouhg dwell at high RPM to keep up to teh demands of these coils.
Ideally I would use 4 bosch coils with a 4 channel ignighter, but I was looking for an easy way out.
MSD is certainly the easy way out.
Just loves wastespark
Actually otherwise there is a bitsa you can put together from mitsubishi parts that is supposed to work well. Can get info if you are interested.
Definaltely interested mate.
See teh basics are that I can go to teh new Microtech ECU and a X4 4 channel ignition box with bosch coild for a REALLY good price, but then I'd need to do a whole lot of rewiring - I'd prefer to stay simple and keep the wiring work to a minimum...
X3 Excel wastespark coils and ignitors are identical to Evo 3 Coils and Ignitors and are supposed to be good for 300kw @ the wheels.
Evo 3 will be rather rare and hard to get but X3 Excel should be easy as. Just go pilfer the system from a wrecker.
The Pupat on Tue Feb 13, 2007 4:58 pm, edited 2 times in total.
'92, Red, Hardtop, Noisy CAI, Even more Noisy Exhaust, AVO Shocks with TJR Springs (Not so Fuli drifto speco).
