what a f*ckstick!!
i can't believe he couldn't figure out how to use the handcontroller? it's a peice of piss. and what's this about it having no memory function?? changes are saved automotically into the memory as soon as they are made.
power delivery should be smooth, because the load points are so close together coz there is so many points. you might need to run thru your map and look for any big jumps / changes in values, and then just tweak the values around it so that the ramp up and down is smooth.
but anyway, you got more power yeah ? at least that is a good sign.
wow, i imagine you are pretty pissed off right now. i sure would be.
