Air horns
C+C
Air horns
Postby C+C » Thu Feb 01, 2007 10:01 am
Hi guys,
Am looking at changing the pissy stock horns for something with a bite, preferably air horns similar to most euro cars.
Is there any specific attachments, fitment issues, types that i ought to know about, or are they fairly universal.
i have an SE, and will taking off the front bumper shortly (for an i/c upgrade), so is this best way to replace it.
Thanks in advance
C+C
Andrew
Postby Andrew » Thu Feb 01, 2007 4:30 pm
Wuey
Postby Wuey » Thu Feb 01, 2007 6:04 pm
Come on Andrew! Aren't you going to blow your own trumpet this time? Show us what you have!
I installed a pair of made in Italy Narva air horns in \"parallel\" with the stock feeble meep-meep horn. They are from K-mart for $25. Cheap as chips. This way, the stock horn will still sound if the air-horns go \"pfffffff\" as they can be temperamental in cold weather. The oil in poor quality or poorly installed or maintained air horns can freeze up and bind the rotors, but mine has never given me any trouble so far. Installing the horn motor in the warm engine bay helps.
The air-horn relay that feeds the motor is connected using a thick 12-gauge wire with an inline 30A fuse tapped directly onto the main 12V bus under the main fuse box in the engine bay.
The relay can be triggered using the spare unused horn wire in the NA. This ensures both sets of horns are trigged at the same time. The stock horn will usually sound a split second before the air horns. Warning: If you wire the relay that connects to the 12V terminal of the air horn motor using the stock horn wire, you are likely to keep blowing the 20A fuse if you step on the brake pedal while using the horn at the same time. The stock horn shares the same circuit as the stop lights. Besides, the stock horn wire is too thin as the main 12V feed to the air horn motor. This wire is only good for triggering the relay.
There is plenty of room in the NA engine bay for the horns and the motor near the air-filter and its intake. Try to heat shrink or tape the main wire at critical areas to prevent short-circuit.
My horns can wake up the deaths in a graveyard. Andrew's trumpets will make them scramble back into the graves. :mrgreen:
Image 2004 SE
Andrew
Postby Andrew » Thu Feb 01, 2007 7:07 pm
Wuey wrote:Come on Andrew! Aren't you going to blow your own trumpet this time? Show us what you have!
:oops:
My setup looks like this -
and sounds something like these when connected
8)
MasterZ
Vehicle: NA6 - Turbo
Postby MasterZ » Fri Feb 02, 2007 9:08 am
watch this vid on the site that Andrew posted
http://www.hornblasters.com/video.php?pic=42
1992 Mazda MX5 Turbo | 2004 VW Golf GTI | 2010.5 VW R36 Passat Wagon | 1985 Mazda HBES 929 13b Turbo | 1987 Mazda RX7 FC3S Turbo | KE20 Corolla Coupe
C+C
Postby C+C » Fri Feb 02, 2007 9:34 am
c'mon fellas....... nothing too loud and big :)
i would prefer something hidden away and doesn't play nursery rhymes
thanks for ideas though
Alf
Postby Alf » Fri Feb 02, 2007 11:20 pm
Also check out this thread
I recommend the genuine Stebel Nautilus air horn, fits like a charm in place of one of the existing horns even on the SE with its intercoolerette.
Alf
JBT
Postby JBT » Sat Feb 03, 2007 10:19 pm
Now you see them.........................
Now you don't :)
pcmx5
Postby pcmx5 » Sun Feb 04, 2007 11:29 am
C+C wrote:c'mon fellas....... nothing too loud and big :)
I have"Crazy Reds "airhorns bought from him in America(he is on the Marketplace at Miatanet).
Easy to fit , good sound, no trouble in 3 years.
I do have socks over the trumpets to stop junk getting up them as they are mounted low.
Peter.
ampz
Postby ampz » Sun Feb 04, 2007 3:15 pm
MasterZ wrote:watch this vid on the site
I Can't believe they blasted a policeman!
ROFLMHO :lol:
Huh?
Andrew
Postby Andrew » Sun Feb 04, 2007 5:16 pm
Make sure you get the 'compact' Nautilus think it would fit better in the OEM space rather than the standard one.
Andrew
Postby Andrew » Sat Feb 24, 2007 12:15 pm
I blew a 10amp fuse with my Nautilus the other day...lucky it was on the additional relay circut i'd installed....so i read the instructions and it required a 20amp fuse :oops:
BTW Auto Barn (in Frankston) stock them. $48.99 for the standard and $59.99 for the compact. 8)
G M Fude
Postby G M Fude » Sat Feb 24, 2007 1:36 pm
Or if you're not from the southern suburbs, East Coast Auto Spares in North Road, East Bentleigh. $47.50 for the standard ones (in the cardboard box), and $54.99 for the compact (in the blister pack).
Andrew, where did you take the power from for the horns? I'm still finding may way around under the bonnet of an MX-5.
Andrew
Postby Andrew » Sat Feb 24, 2007 1:45 pm
G M Fude wrote:Or if you're not from the southern suburbs, East Coast Auto Spares in North Road, East Bentleigh. $47.50 for the standard ones (in the cardboard box), and $54.99 for the compact (in the blister pack).
Thats where i purchased mine from 8)
G M Fude wrote:Andrew, where did you take the power from for the horns? I'm still finding may way around under the bonnet of an MX-5.
Give me a minute and i'll go and take some pics for you.
Andrew
Postby Andrew » Sat Feb 24, 2007 1:59 pm
Ok here goes -
Power comes from the fuse box under the bonnet, the black wire in the middle of the picture -
...it then runs through an inline fuse (not picuured) that i blew and onto the relay -
I used the trigger from the OEM horn to switch the relay and provide power to the new horns along with an earth.
The horn in then tucked up infront of the radiator using a custom bracket -
Users browsing this forum: No registered users and 190 guests
