Headrest Speakers
- Garry
I have a small Pioneer 2 channel amp in my drivers side tunnel. It's been there for over 3 years without any problems. There's 2 advantages mounting it there, it's stealth and doesn't take up any boot space. The disadvantage is that you are limited to only a few amps that are small enough to fit there.
- Charlie Brown
I can’t believe the number of posts here saying forget the head rest speakers.
They are without doubt the best system in an open top car around. Sure you only get mid & high range frequencies but the door speakers fill in the bass.
With the NA and all its associated wind noise on the freeway go out and find a reasonable set of 3†or 3.5†speakers and don’t forget the passenger seat, you won’t regret it.
- jules
- Guitar Hero
- Hot Rodders
Charlie Brown wrote:I can’t believe the number of posts here saying forget the head rest speakers. They are without doubt the best system in an open top car around.
i have to disagree with that. the first mx5 i ever rode in had the headrest speakers and i thought they sounded tinny and horrible. couldn't hear any bass from the door speakers at all.
of course this might have just been due to the way he had the stereo settings dialled in.
also i just don't like the idea of having speakers so close to my ears. i have a set behind the seats on the parcel shelf, i find this works really well. i never have any trouble getting enough volume and i'm not running a seperate amp.
- Ajay
fatty - its not 2 bad with a 4\" in it... the leather muffles alot of the sound bringing it down quite a few levels.. just enough to blend with the front splits..
WHERE ARE THE REAR SPEAKERS IN CARS THAT DONT HAVE HEADREST ONES...
my cousin has a black 93.. and hit has little 8\" subs mounted in the base of the seats facing the floor.. but i doubt that was stock lol
- Craig
- Vehicle: Non MX-5
STV wrote:the stock door speakers in the NA are 4" too arent they?
Std NA door speakers are either 6 inch or 6.5 inch, can't remember which exactly. I had 6.5 inch ones mounted in mine, without any mods to the door or trim etc. Jaycar do some pretty good co-axial 6.5 inch speakers....
- Craig
- Vehicle: Non MX-5
They are a 6 inch with a 3 screw mounting system from memory but I think I wedged some 6 1/2's into mine.
*** Audi Q5 55 Sportback - HYBRID! Zero -100 in 5.3 seconds!
Well it's just that for ultimate sound quality, headrest speakers are in a very poor location. Ever sat with your back to the stage at a concert? Not quite the same
I had 6.5 inch splits in both my NA's, powered by a 90w per channel amp, and never needed to have the volume above about 60%. Sounded fantastic, and had very good bass also. Never felt like I needed more volume. It can be done folks, and these days it's much cheaper than even 5 years ago.
