the truth about hub fitment
So I've read a lot of conflicting opinions about whether or not the hub actually does anything in terms of bearing the load of the car.
Does anyone know the \"truth\" (hopefully substantiated by some conclusive evidence) regarding this issue?
Is it okay for the car to run on wheels that are just held in by the wheel nuts (lugs)?
I have several aftermarket rims I can fit to my car but I'm hesitant since none of their centre holes fit perfectly with the hub of the car. Should I be worried about this?
Thanks
Thanks
- deez
- deez
Re: the truth about hub fitment
atomic wrote:I have several aftermarket rims I can fit to my car but I'm hesitant since none of their centre holes fit perfectly with the hub of the car. Should I be worried about this?
Thanks
I think he means the centre hole, not the PCDs. I could be wrong though
89 Eunos Roadster
- kitkat
The hub is meant to take the load of the cars weight... the whee nuts are just there to hold on the wheel.
It doesnt mean the nuts wont do it... we have the rims held on by the nuts and have had no problems. Had the car over a year now, has been around many corners and i've never had any problems.
But as been said... you can get rings to match the size of the hub.
- greenMachine
Rant mode on/
Furphy!
Just another unnecessary americanism ... they call them 'hub-centric' rings, the alleged purpose of which is to ensure that the wheels/tyres are absolutely centred.
Ask yourself what role a piece of plastic is going to play, when the wheel nuts are tightened up ... then the car's weight is loaded onto the wheels ... then the cars is pushed hard through the corners (perhaps on the track with R-spec tyres or even slicks).
And then ask yourself what we did before the yanks 'discovered' them.
As I said, a furphy, but if the yanks use them, they MUST be good - mustn't they?
/rant mode off
What the hell, they are only a couple of bucks, and if you feel better using them, go for it.
Furphy!
/rant mode off
They're just for centering/locating the wheel on the hub, i've been through a couple of track days and many drift days without hubcentric wheels with no ill effects.
Theres no way a thin bit of metal bout 5mm thick will hold the cars weight better than 4 ~10mm diameter bolts.
It'll be fine, just put the wheels on and post up a pic!
Dave
Dave
- Garry
- Garry
Indeed you did but never let the whole truth get in the way of a good story
The weight of the car is supported entirely by the circlip until the damper runs out of suspension travel then the weight of the car is held by the shock body. (Assuming that the springs have been designed correctly and they dont bind before it runs out of suspension travel.)
But hub rings are only used to locate the wheel centrally on the hub to reduce the likelyhood of vibration. If you are using only the wheel nuts to locate the wheel then you need to make sure the taper on the bottom of the nut matches the one on the wheel and to do them up evenly. I have plastic hub rings on my wheels so they wont be supporting much weight.
- greenMachine
Interesting point Garry.
I suspect that the forces acting on that circlip are not as high as you imply. To start with, the gross forces cannot exceed the sum of spring rate times deflection, and all other forces are taken out through the shock rod, bushes and bump stops. It is too late for me to do the maths, but as well as a simple multiplication above, it would also involve the area of the contact surface between spring seat and circlip, and circlip and shock body.
From what I recall of that setup, those forces are acting in shear along the body of the shock absorber, which if I remember my physics is a lot better than some others.
Engineering-wise, I think that the forces there are much more manageable (and moderate) than those at the hub. I think that the dimensions and nature of the materials involved at each location is evidence to support this hypothesis.
Then again, I am no engineer, so what would I know?
EDIT - to calculation above, add in the weight of the car that that corner is carrying
- Benny
I know that many MX-5 race cars do not have hub spacers, and they haven't had any problems.
However, I have always made sure that any aftermarket wheels that I have bought, come with the correct spacer and I do always fit them.
Just about any tyre/wheel place will have them in an assortment of sizes.
- Garry
Try an experiment.....take the springs out and see how well the shock rod supports the weight of the car. It wont. It will compress until the car is resting on the bump stops. The springs support the weight of the car until they are compressed enough by a large bump (like a pothole) for the bump stop to hit the shock body, the shock body and bump stop then support the car. What is supporting the spring while all this is happening? Nothing but the circlip. All will work fine as I'm sure all the forces involved have been carefully calculated with a reasonable safety margin built in. And you are correct, we are only talking about sheer forces on the circlip. Things start to turn pear shaped however when the wrong springs have been used and the spring totally compresses (binds) Then the larger forces normally taken by the shock body and bump stops are now transmitted through the circlip.
