** I did it, cold side air intake on the NA ** new pics **
- deez
- SuperMazdaKart
- Boags
deez wrote:What about relocating the water bottle and all that jazz? And the metal water hose as well?
You're right! 2 x Tech screws also!
- Sean
- Astroboysoup
yeh i remeber he had a pic of it on his car domain site.. i found his car domain site but no pic of it anymore
some of his images are missing..
http://www.cardomain.com/ride/188714/1
- Bevan
- Astroboysoup
- Astroboysoup
so now you just need to tune your vpc thingo to get max power out of yr setup. is that even possible? can you tune that thing to lean it out a bit? as it sounds like yr a bit rich now from what you've said?
if not it might be possible to add a DFA to lean it out to get better response and more power. that's be another $150 or so.
- Astroboysoup
yeh perhaps... that might help me even more.
i have to get on a dyno to see air/fuel
my a/f meter isn't the best..
but i have tuned it better now.. idle was the main problem...
ive been turning the knobs the wrong way.. instead of leaning out the mixture i've been adding more... alot more.. hence the puddles of fuel.. but i figured it out this morning on the way to the garage. i got it about 8% leaner than what it was and its like driving it with the stock afm back on. I also moved the temp sensor on to the throttle body. tapped a nice screw hole just behind the throttle body to get a better and more accurate air temp.
im sure if i have the DFA it will get even better..
i also bumped the timing up to 16 degrees advanced.
- SuperMazdaKart
- Bevan
I did on my NB. I just cut the wires half way, put some new wire between the cuts and connected with spade connectors. Easy as that!kev.yan wrote:Has anyone done a cai on the cold side of the engine bay and kept the standard maf by relocating and re-wiring it to the cold side.
Kev
